My TR3A has a TR4A engine, per the block and head numbers. I recently rebuilt it with very many new parts including pistons, valves, cam, timing gears and chain, all new motor mounts, etc. etc. I had the main rotating parts balanced by an experienced machinist including pistons, each end of the rods, crankshaft, flywheel, and clutch pressure plate. The machinist punch marked the crank flange, the flywheel, and the clutch pressure plate and told me it should be reassembled just exactly as he balanced it. So I double verified that I had everything lined up to his punch marks. My problem is that I was expecting it to run with almost no vibration. However, when I put my hand on the front of the cowl and the fenders I feel quite a lot of vibration. Also when I put my hand on the bottom of the oil pan I feel quite a lot of vibration. And if I put my hand on the side of the valve cover I can feel quite a lot of vibration. Another test I was told about is to put a flat bowl of water on the hood (bonnet) and the movement should create a nice concentric set of circles in the water if it's running good with not much vibration. But what I'm getting is a just a big movement of the water and no circles. I have not tried this water test on my TR250 but I do not feel nearly the vibration on my TR250, of course it is a 6 cylinder. Is it normal to have quite a bit of vibration in the 4 cylinder Triumph engines even after having them balanced? Thanks!
Regards,
Bob
Regards,
Bob
