Just installed rebuilt motor/trans with all new clutch, pressure plate (PP), and throw out (TO) bearing. Clutch fork bushings all good, no slop, fork straight, rebuilt master and slave cylinders. After bleeding system, everything seems to be working fine except. While relaxed the rod out of the slave cylinder is tight on the fork. There is no free play at the fork at all. Seems tight and am concerned in this state the TO bearing is too tight on the PP. The motor and tranny have not yet been started or tested.
The clutch is definitely releasing and engaging for when in gear I can not turn the output flange of the tranny (no driveshaft installed yet) and with the clutch pedal in, I can move the flange easily by hand.
I scanned prior posts and could not find a good answer as to how much, if any, free play there should be. I would think one should feel a little slop. If a little free play is necessary how do we achieve this? Shorten the push rod out of the slave. Am I missing something?
??????Help
Thanks
jjs64bj8
??????Help
Thanks
jjs64bj8
