Clutch fork lever
Martec
Member
Hi Can anyone tell me how to remove the tapered pin that keeps the clutch release fork in place with the fork lever shaft. Which way do I need to tap it for it to come out?
Thanks
Mark
BobHaskell
Mark,
The tapered pin's larger diameter is on the flywheel side. There's a hole on the rear side of the bell housing that you can put a punch through. Clamp the lever arm so it's perpendicular to the punch and so it won't rotate. I've had mixed results knocking the pin out.
Cheers,
Bob
Jack T
Mark,
Cheers,
Bob
I've been watching this thread as I was just about to post the same question. If you've had 'mixed results' knocking them out, is there any alternative? Seems the fork has to be removed to get to one of the bolts attaching the ball housing to the 'box.
Thanks.
Thanks.
1) Drill it out. 2) Nope. I've separated the box a couple times w/o removing the fork; wobble extensions help IIRC.
BobHaskell
I don't remember there being an issue removing the bell housing from the gearbox, but it's been a while. When using heat, keep an eye on the plastic washers on either side of the pivot arm. I don't know if they're available new. I made a couple on my metal lathe.
... When using heat, keep an eye on the plastic washers on either side of the pivot arm. I don't know if they're available new. I made a couple on my metal lathe.
Moss, at least, doesn't have the plastic bushings. BCS may have them, but they should be reusable.
I did this a couple years ago, and my memory's a little hazy, but IIRC:
- Moss has the shaft and the bushes separate, for about $46 total, but they don't sell the tapered pin separate
Moss has a kit, that includes the tapered pin, for about $60, but the bushes weren't quite right, nor was the tapered pin (and, I think, when I drilled the old pin out I opened up the hole a little; I'm not sure I didn't just put a roll pin in there and called it a day)
Yep, I ended up buying both, because I bunged a bush from the kit, so bought the bushes and shaft separate. I didn't like the way the parts from the kit fit, but don't remember exactly why (I think the bushes were shorter than the original or the separate pieces).
Note carefully how this mechanism comes apart, as there's a sequence to getting it back together. The hole for the bush on the bottom is a blind hole, so you want to drift it in first before you put the bush in the top end (don't forget the plastic spacers).
The shaft has a threaded hole on the top, and it should have a cheesehead screw in it. I stared at it for hours trying to figure out what the purpose of these are (besides being some sort of sick Limey joke ;)). Finally decided the screw should be removed, or backed out a little so you can get a puller on it, or thread a puller into the shaft to extract it.
Of course, replace the boot on the shaft, and I found a plastic hole plug to fit the hole in the bell housing as it seems dust can get in though it.
Kainopong
Member
I beat on mine for two days before I finally gave up. My mechanic said he just cuts the head flush and then drills it out. He said most of them are seized tight and if you cannot get a pin to knock it out from the back end (grind flush first) the only option is drill. It is one of the most difficult tasks IMHO
Drilling most of it out weakens it enough to be driven out with a pin-punch.
bob hughes
Well some 6 years ago I had a similar problem, the bearings were worn. Like you guys I spent a lot of time getting nowhere so I took the whole bell housing to Rawles and let Rob have a go at it.
It was the original type mild steel pin that is tapered and he went about it in a totally different way - he drove the shaft itself out with several judicious blows of a hammer breaking the pin in two places then removed the remnants of the pin from the different parts with a drift. The bushes were installed and a roll pin was put back in to lock the shaft. It is to be noted that Rob said that you can not use this method when a spring steel roll pin has been used and that you do not spend time pounding on the shaft as you could distress the aluminium.
:cheers:
Bob
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
D Clutch Fork Pin Removal Austin Healey 4
D TR2/3/3A Clutch through out fork misaligned Triumph 17
KVH General Tech Clutch Fork and Broken Pin Triumph 8
T Clutch Fork removal/rebush Austin Healey 3
Lukens TR2/3/3A Clutch fork pin. Triumph 9
J Clutch fork free play on BJ8 How Much? Austin Healey 13
S TR2/3/3A remove a clutch fork Triumph 1
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
AHS TR2/3/3A TR3 transmission clutch fork & shifter removal? Triumph 5
K Clutch fork fix Re: the 1/4" bolt repair. Triumph 10
KVH Clutch Fork Lock Wire Triumph 1
J TR6 TR-6 Clutch Fork Cross-Bolting ? Triumph 2
J TR6 TR-6 Clutch Fork Taper Pin-Torque ? Triumph 5
KVH TR4/4A TR4A Clutch Fork and Shaft Triumph 37
dondel Clutch Fork movement & Master Cylinder Austin Healey 13
hondo402000 TR6 New TR6 Clutch shaft, fork and beefy pin Triumph 3
Banjo The dreaded broken clutch fork pin! Triumph 9
J Clutch Fork Clearance Info Request Spridgets 2
CCURTISS T-Series Extra MGTD/TF Clutch Actuating Fork???? MG 2
GT6_Mark T-Series MGC Clutch Fork Question MG 1
CCURTISS TR4/4A TR3/TR4 Clutch Fork Install Question Triumph 8
heliguy TR5/TR250 TR250 clutch fork "pins" Triumph 2
heliguy The dreaded clutch fork pin again..... Triumph 9
tomshobby clutch shaft/fork pin Triumph 8
B Clutch Fork Austin Healey 3
B Clutch fork shaft rebuild. Austin Healey 9
I Broken clutch fork taper pin Triumph 6
M Clutch Fork Pin Triumph 4
martx-5 Gearbox Clutch Release Fork Triumph 2
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
