Clutch release arm / fork gaiter ; Toyota 5 speed conversion
BBH
All,
Re the Toyota gearbox conversion and specifically in respect of the bellhousing, there is a rectangular hole where the clutch release fork comes through to link with the slave cylinder. With the kit I purchased I didn’t get any form of gaiter /
seal, but I have seen mention of them.
Does any-one have a part reference (Toyota or otherwise) for the gaiter / seal.
rjc157
Just curious did you get your kit from Pete anyway the number your looking for is Toyota bellhousing rubber #31126-20060 good luck
B
BBH
Many thanks for the part number reference - just what I was looking for.
Re the kit, I did try to contact Peter a few times (e- mail and phone) but no-Lucy so I bought a kit from a UK supplier
K Missing spring clutch release lever Other British Classifieds 1
S TR2/3/3A TR3 clutch release bearing... from Home Depot? Triumph 12
B Clutch Release Bearing Austin Healey 2
Jer Confirming the best choice for clutch / release bearing for my 67 Midget Spridgets 2
W General Tech Clutch Release Question Triumph 6
B MGA Clutch release bearing MG 4
C Clutch Release Bearing Austin Healey 5
T Clutch release bearing question Spridgets 10
Xte New clutch release bearing completely detroyed ... Austin Healey 4
K TR2/3/3A Clutch Release Bearing Triumph 4
B Ball Bearing-type Clutch Release Bearing for BN2 - Availability ??? Austin Healey 2
K TR2/3/3A What's the easiest way to remove the clutch release bearing from the bronze sleeve? Triumph 7
K TR4/4A TR4A Clutch Release bearing Triumph 6
abarth69 1275 Clutch release bearing Spridgets 18
O sprite clutch release Spridgets 1
S TR2/3/3A TR-3 clutch pressure wouldn't release Triumph 3
mountainman TR2/3/3A TR3 Clutch Release bearing Triumph 2
drooartz Clutch release lever bushing Spridgets 12
Thor 1500 clutch release bearing removal -how to do it? Spridgets 4
middleagecrazy Clutch Release Bearing Spridgets 3
M TR2/3/3A TR3 clutch release bearing Triumph 3
T Clutch release bearing.... Spridgets 14
D T-Series MGB GT Clutch Won't Release MG 5
T Slow clutch release Spridgets 6
R6MGS T-Series Clutch Release Bearing MG 5
martx-5 Gearbox Clutch Release Fork Triumph 2
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
KVH General Tech New Clutch Installation--TR4A Triumph 5
