Ummm.... just a humble opinion based on experience but: hydraulic systems *will* bleed down eventually using the prop on the pedal. The same thing has happened with many cars ( and of different makes) in my past and it seems to help if you FIRST run the car up to operating temp in neutral, then proceed to find said level area... use second gear, start 'er onna key with clutch depressed (after ascertaining there's full movement of the clutch fork with clutch depression, ruling out hydraulic failure as the culprit) and accelerate... if said "BANG" is missing after a few attempts, a short, sharp "STAB" or two onna brake pedal (clutch still on th' board) while under way should produce the desired traumatising result. Very disconcerting but effective.
CAUTIONARY STATEMENT: This proceedure WILL stress driveline components and may result in the necessity to replace worn or weak U-joints. Just a "heads-up."
