MGB 1978 MGB clutch is out..!
Guywith2Mgs
Car ran great 2 years ago but sat. It starts fine but clutch is to the floor. Not an expert here but can figure stuff out pretty well. Any first checks before i jack up the car/go crazy on this thing? thank sin advance and love this place already!
Platinum
Hydraulics, most likely. To do it right the first time, rebuild or replace both master cylinder and slave and replace the flex line. A pain, but then there's no guessing. And if it sat that long in other than climate controlled conditions you should consider doing the same with the brakes.
drooartz
I'm with Doc on this -- start with the hydraulics first. Straightforward enough to do if a little fussy. Hopefully it's not anything with the clutch itself, as that requires engine-out to fix.
YakkoWarner
The MGB clutch slave is really easy to do - I did one in an on-street parking spot in front of an Italian resturaunt once because thats where it died (put the right side front wheel up on the curb to get a little room and did it in an hour or so). I know its basic, but check for fluid. If theres no fluid in the master, and no suspicious evidence of fluid under the master (inside or out), then I'd change the slave 1st. If you have fluid, then its not leaking and may just need a good bleeding. Complete replace or rebuild will certainly eliminate any doubts, but a simple bleed or slave swap could get you down the road quick if the master isn't failed.
I'm looking at the same problem on a 1984 Jeep XJ and it is NOT easy - the clutch slave is on top of the transmission and can only be accessed by dropping the trans (or cutting an access in thru the floor). I'd rather do a dozen MGB clutch slaves than one on that Jeep.
Platinum
Easiest/quickest is Moss Motors. Don't forget the flex line.
Grantura_MKI
One word of advise. If you care about originality, keep the ones you are removing and send them out to be sleeved.
The replacement units will be generic units and will work fine but will not look like the originals.
As Doc says, Moss sells a complete kit with all the bits you require. I believe the part number is 180-718 and sells for less than 60 USD.
Platinum
Hence my: "Easiest/quickest" comment.
I am a guy with three MGs.
And experience with dozens more! 😉
I'd be for sleeving the originals in any event, if the MG in question is a pre-'68. :devilgrin:
Bendure
Hello - similar problem - acquired a 77 MGB - clutch pedal goes to the floor. Removing the slave cylinder rusty/watery oily mess spilled out taking off the boot so waiting on a new one ordered. Question - The master cylinder contains full / clear looking brake fluid - when removing the slave I was expecting the flex hose to start draining out the master fluid - but nothing came out. Could this be due to lack of pressure or could the entire line be clogged somewhere?
Thanks for any insight!
JPSmit
not likely clogged - might just be that the Master isn't vented and therefore the lack of opportunity for air to ingress is holding the fluid back. Also the fluid itself doesn't always flow that quickly.
You could try taking off the MC filler cap to see what happens - though even then it won't be quick, more like drips.
Platinum
Since the system is already "opened" a suggestion would be to replace the flex line as well. The old "ounce of prevention" paradigm. 😉
bobhustead
And you could try cracking the line at the master and having your helper push the pedal down. Close the line before pedal is released.
Bob
Bendure
Cracked the line moving pedal does not seem to cause any fluid to move or escape - sign of a bad master cylinder?
JPSmit
Is there fluid in it?
M For Sale 1978 MGB MG Classifieds 0
R For Sale Time Capsule 1978 MGB MG Classifieds 1
S MGB Newbie 1978 MGB questions MG 11
B MGB anyone have a photo of a 1978 MGB dashboard to left of steering and console ? MG 9
B MGB 1978 MGB 2 wires hanging under the dash to the .. MG 4
rick_ingram MGB Wheel Upgrade - 1978 MGB MG 6
rick_ingram MGB Awakening my 1978 MGB - No Results MG 4
C MGB Radiator fans - 1978 MGB MG 11
M MGB 1978 MGB Headlight Ring MG 8
M MGB Drive Shaft U-Joint, 1978 MGB MG 4
N MGB 1978 MGB Coolant Level Checking MG 3
G MGB 1978 mgb courtesy light needed MG 1
G MGB windshield washer system 1978 MGB MG 9
M 1978 London Taxi Passengers Other British Cars 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
S MGB 1978, replacing the clutch. MG 3
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
M MGB 1978 mg fuel smell MG 23
M Hello again. I have a 1978 Triumph spitfire. Triumph 17
Kleykamp For Sale 1978 MG Midget Best Offer Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget photos added Spridgets Classified 0
Kleykamp For Sale 1978 MG Midget project or parts Spridgets Classified 0
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
TomR 1978 MG Midget with Points Distributor Spridgets 4
rovernut 1978 with black seats..biscuit interior..Original? MG 2
L 1978 mg midget seat belt replacement Spridgets 3
AngliaGT 1978 Datsun B210 - Where Do I Go From Here? Other Cars 11
R ?'s re 1978 Midget MG 3
KLUTZ MGB-GT 1978 fuel tank.. compatible with my 74.5 GT? MG 6
J Spitfire Current Leakage, 1978 Spitfire Triumph 14
JodyFKerr Spitfire 1978 Spitfire 1500 Triumph 32
M 1978 MG Midget 1500 Original Paint Color Options Spridgets 11
J Electric choke-MG Midget 1978 Single Weber Spridgets 4
dpcsix 1978 scca nationals champ Spridgets 8
dpcsix AH scca 1978 nationals champion Austin Healey 0
J Windshield washer 1978 midget-bag on fender system Spridgets 0
regularman Its a 1978 and I want it. Spridgets 23
J Firing order 1978 Mg Midget 1500 Spridgets 7
Sarastro Thoughts on a 1978 Mercedes 450SL Other Cars 3
J Where is the brake light switch? 1978 Mg Midget Spridgets 9
J Oil pressure gauge -on 1978 Mg midget 1500 Spridgets 6
B Will a 1978 Midget Steering Wheel fit a '79 Midget Spridgets 6
J Spitfire 1978 Spitfire Distributor Amplifier Module Triumph 0
J Spitfire 1978 Spitfire Horn trouble shooting Triumph 10
M 1978 Eleectrical issues MG 17
L Paint name for 1978 MG 4
Guinn draining and refilling coolant, 1978 B MG 9
J 1978 MG Midget For Sale [florida area] MG 0
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 0
