Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
I think it is right but the car is not running well and I changed the wires-one at a time? The order listed is 1,3,4,2 but where do you start #1 on the cap, and where does # 3 go? thanks Jim
I recently wrote a PDF document for setting static timing. It has a supplemental section talking about firing order and spark plug wire placement. Please download it and see if it doesn't answer your questions. https://home.mindspring.com/~purlawson/files/StaticTiming.pdf
Succinctly, find #1 TDC (when the cylinder closest to the radiator is at the top at the end of its compression stroke). Look at where the rotor is pointing on the distributor cap. The lead on that position goes to #1 cylinder. For Lucas 4-cylinder dizzys, the plug wires go CCW around the cap so the next position after #1 is the spark plug wire for #3, then #4, then #2.
Thanks again to Doug for a well written document specific to one operation too many find daunting. Good-on-ya! 'specially the "re-read" part! /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
