TulsaFred
Trying to place my dizzy and set static timing.
I have a side entry distributor cap with two "low" posts and two "high" posts.
I believe the firing order is 1-3-4-2
At TDC of cyl 1 the rotor is pointing to approximately 2 O'clock, which corresponds to a "low" post.
If the rotor turns clockwise the next post is a " high" post which I assume goes to number 3 cyl, then another "high" post to cyl 4, and finally the last "low" post to cyl 2.
Does this sound correct?
Fred
Fred
