MisterB
Hi Folks-
Getting ready to button up the outer structure on the right side of the '67 BJ8. Here's my plan of attack-
Outriggers were done by the PO, so--
Inner sill- stitch weld 1/2s together, locate to front wheelwell and attach along length to outriggers and rear.
Attach rear shut panel and door hinge panel to sill.
Outer sill.
Floor pan.
Seems intuitive, but I thought I would check.
Also, what is the consensus on applying a bit of upward push to the inner frame section while this work is going on? Bracing the door opening? I do have the door where it will close and latch now with the sills and floor unattached, just held with welding clamps. The right side was done long ago and has required some tweaking on my part to get things lined up better.
The engine and tranny are in situ and bolted loosely in position.
I am new to Healeys and am muddling through with much help from the archives. Thank goodness for it!
Thank you,
Mike Burgess
Albert, KS
Outer sill.
Floor pan.
Thank you,
Mike Burgess
Albert, KS
