Looking for DS Outer Rocker - Front 4"
Jim_Gruber
Anyone got a partial DS Outer Rocker. I need the front 4" to fix a spot right behind DS wheel that rusted immediately and quickly in spite of dry garage storage for almost all of the last 10 years. Leading edge is all perforated right at the right angle compound curve. I can fabricate but looks like a lot of effort to duplicate the curve + putting a right angle in it to match the wheel well curve. Rest of Rocker just fine.
Also anyone got a picture of the End Cap Installed on front of rocker. This is a closing panel that DPO I believe never installed MOSS part 452-150. Goes between inner sill and rocker. Hard to see with road grime and dirt in there.
Thanks in advance.
mightymidget
Re: Looking for DS Outer Rocker - Front 4"
I purchased a set of sills off of e-bay that were inferior to what moss sells, so I ordered a set from moss. the ones I have do not roll over the edge under where fender meets sill. My computer crashed from virus so I cann't post photo of mine. if you can post photo of area you neeed patch I may be able to tell you if what I have will work.I'm leaving today at 3 pm but will not be back till tuesday
Jim_Gruber
Jim_Gruber
Got to get the camera out. I'll post a pic of what I need.
Jim_Gruber
Jim_Gruber
Found a set locally in Cincinnati I can have for a song and someone else set me pics on how to hammer one out over a plywood form. Locally is easier, cut to fit, Frank C. sent info on how easy this repair. Either way, next weekend I take on the DS Rocker. Thanks all.
mightymidget
I am in the process of replacing my passenger side complete outer sill now. I have broken the top loose, the only issues I have had so far is getting the sill off footwell upright. I ended up ripping some holes in the side foot well. realized that if I used a chisel from the inside pushing up once welds were drilled that they didn't rip footwell wall.
any pointers on removining the bottom welds? do you do it from the backside or from the front?
Jim_Gruber
Jim_Gruber
I haven't been there before. Others will chime in here please.
mightymidget
great photos Mark, I think you are doing a fantastic job, The part I am not sure of is the floor/inner sill to "outside sill". I have removed the top welds from outer sill, All I have left to remove is the bottom of orginal outer sill
Not real sure where at the bottom I need to split to find factory spot welds. I would think they will needed to be drilled out from the front under the lip of outer sill.
I have taken by metal cutter and cut the old sill face off so I can work either side Of where the parts come together. Makes sense to me they would had oringally been welded from under the floor boards to outer sill, or from the front under outer sill lip
markberry
Thanks for the kind words.
The inner and outer rocker panels are in fact spot welded together along the bottom. This is a seperate weld joint than the spot welds that hold the floor to the inner rocker panel. These welds aren't hard to get at, it's the welds that hold the "A" post to the outer rocker, The welds that hold the outer rocker to the inner rocker behind the "A" post/lower hinge, and the welds behind the quarter panel where the outer rocker is spot welded to the inner quarter panel (I have a picture I'll post)that are difficult. At some point in my car's past, someone cut the old outer rocker away, leaving the original factory welds, and pop riveted and brazed a new outer rocker to the original flange. Not a great way to repair a structural member. I could go on for hours with stories like this but I'm sure you've heard them before! Let me know if there's anything I can further help with.
Regards
Mark
https://www.spritespot.com/gallery/view_p...=wiper_mech_003
https://www.spritespot.com/gallery/view_p..._post_repairs_2
sim looking for 2 valve spring kippers for a 948 Spridgets 3
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
E TR6 looking for info on doing a T5 swap Triumph 5
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
BJ8Healeys Location of VIN tag, 1964 Sprite HAN8L43421 (I know it's stamped on the frame. Looking for the tag.) Spridgets 8
T Looking for "BillMs rear transmission mount" Spridgets 2
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
V Wanted Looking for SU HIF4 Linkages. MG Classifieds 0
Got_All_4 TR6 2nd Gear Bush Problem TR6 Looking at Steel Triumph 12
JPSmit A fairly specific looking bolt Spridgets 10
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
R Wanted Looking for an original AH 3000 Mk1 Drivers Manual 1102B. Austin Healey Classifieds 1
T Looking for recommendations re using a Seacan for vehicle storage Spridgets 7
BJ8Healeys Looking for BJ8 VIN HBJ8L40768 Austin Healey 0
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
M Looking for Lucas parts catalogue British Motor Corp 13
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
idlehands GT6 What gotchas when looking for a GT6+ Triumph 10
BillyB62 TR2/3/3A Looking for the Owner of a TR3 Triumph 5
Got_All_4 Wedge Looking at a Local TR8 For Sale Little Ruff Triumph 1
roscoe The future is looking up Austin Healey 4
DrEntropy Looking thru old pix Other Cars 8
T 1972 MGB GT for sale in San Francisco, looking for a good home MG Classifieds 1
vping T-Series Looking for TD Part # MG 3
T Wanted Looking for a solid [but doesn't have to be perfect] 100-6 Austin Healey Classifieds 17
F GT6 Looking to sell - in progress restoration Triumph 19
Lin Looking for a part Spridgets 1
Lin MGB MGB and MGC - looking for a part MG 1
H Wanted Looking for TR4A intake # 307455 Triumph Classifieds 3
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
steveg TR6 Newbie looking for hopup guidance Triumph 15
Guido36 Looking for upholsterer recommendation for Healey 100 in Southern California Austin Healey 5
SherpaPilot TR6 Looking For Opinions on Seat Covers Triumph 9
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
R TR6 Looking for Oil Filler Cap TR4/TR6 Triumph 7
pbraun Looking for 64 or 65 Mokes British Motor Corp 0
T Looking for a temporary cup holder - but my heart is pure Spridgets 9
angelfj1 TR2/3/3A Possible UK Source for Authentic looking Clutch/Brake MC Triumph 5
catfood Looking for suggestions - ignition issue Austin Healey 6
W Looking for engine rebuilding 100-6 Austin Healey 12
C Looking for SoCal restoration shop Austin Healey 4
