Sealing new outer panels on BN1
ian_h
Hi
I am having new outer panels fitted to a BN1
The upper join is with the metal beading but should the lower join be just metal to metal or with some form of sealant?
Thanks
Ian
Keoke
Hi Ian, No sealant is not required as well painted mating surfaces adds enough protection against rust and corrosion.---Keoke
I
ian_h
great thanks
I went back to check and you can see light between the wings.
They tell me this is normal to let water drain out of the wheel well between the wings !
Surely this is just nonsense?
Ian
Keoke
YEP-That is pure nonsense
Those panels have not been assembled correctly or were not properly fitted prior to attempting to paint.--Keoke
TonyR
We have a 100 4 and when we replace the outer panels we will use a non setting sealer called DumDum. It is available from Frost in the UK. It is used by proffessional restorers and enables a water free joint to be made.
We have used in on a number of TR3s we have restored to good effect.
Tony
Keoke
----- :savewave:
Dang old habits are hard to change- :cheers: -Keoke--
Tony
Tony,
Where do you use the DumDum (besides the front shroud to scuttle area)?
richch
Any kind of sealant between shrouds and wings will result in water being trapped in there where it cannot escape and/or dry, and will cause eventual corrosion all over again.
richberman
Rich,
Are you saying to not even use the roll of black sealant I bought from AHSpares to seal between the shroud and wings on the top?
Rich
TonyR
The sealant we use is to keep water out. It is elastic and will move with the bodywork and not crack.
You do not want water to be present where wings are fastened to the shrouds etc.
These areas are where muck and mud will congregate and soon start to rust.
Tony
Keoke
----Hey Rich!!!!---- :iagree:
B Steering Column Wiring/Sealing Austin Healey 1
D TR2/3/3A sealing master cylinder pocket Triumph 8
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
T TR6 TR6 Carb Gasket Sealing Triumph 1
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
nichola TR6 Classic Technologies front sealing block Triumph 7
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
BN6_2197 Sealing my legroom Austin Healey 11
G TR2/3/3A sealing body seams? Triumph 12
B General Tech Wire wheel sealing bands? MG 4
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
M TR6 Front sealing block Triumph 11
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
T TR2/3/3A TR-4 Sealing Block Triumph 2
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
S TR2/3/3A Wire Wheels Sealing Triumph 17
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
R removing black seam sealing Austin Healey 3
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
TRMark Being my own DPO, stripped front sealing block Triumph 6
Nelson Sealing exhaust pipe junction Spridgets 14
KVH TR4/4A TR4 Front Sealing Block Triumph 2
T sealing oil leaks in a horizontal joint Spridgets 6
O TR2/3/3A TR3 Winshield Sealing Triumph 9
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
A Sealing exhaust leak - help! Triumph 20
S sealing shim pack Triumph 2
Brosky Sealing blocks are available again Triumph 5
LastDeadLast Brosky - Front sealing block info? Triumph 15
I Bugeye gas tank sealing ring help Spridgets 2
MTribe special bolt for copper washer on sealing block? Triumph 2
Brosky Sealing of Saddle Block in front of engine Triumph 7
steveg Rear Engine Plate sealing question Austin Healey 8
B Sealing block and good thrust washers Triumph 5
J What kind of compound to use as wing2body sealing Triumph 6
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
PATR8 Windshield sealing Triumph 2
Nunyas Sealing a vented oil fill cap MG 6
Ed_K Sealing the gear carrier to the rear axle case ? Austin Healey 8
G Sealing Block Triumph 6
cdsmith "sealing" gas tank sending unit Spridgets 8
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
tr6web Sealing, lubes, etc. Triumph 8
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
