TR2/3/3A sealing master cylinder pocket
CJD
That little square plate on the back of the pedal box? Actually nothing. It's an access plate to reach the hydraulic lines. You could seal it if you wanted to, but best to use something easily removed if you have to reach the lines.
deuce
Sorry..I wasn't completely clear. Not the access plate but the whole pocket held in place to the firewall by seven bolts. Then the master cylinder is mounted in the pocket.
Graham H
I used dumdum a non setting sealer unfortunately you can't buy it any more because it has something in it that's not good for us but I am sure there are altunatives out there that will do the same job
Graham
sp53
Originally they had a black tar like substance seam sealer for the whole assembly. I used rubber based caulking last time. I think it was gray and called Butal rubber or something very common and paintable.
steve
deuce
Thanks for the input guys. Seems the consensus seems to be as caulk of some sort. I was considering like inner tube rubber cut into strips. For the sake of conversation, what would you think of that?
CJD
If you don't mind taking the time to cut and fit it, it should work perfectly. Glad it helped, Steve. I know every paint supplier sells the butyl stuff, but at a real mark up!
B Steering Column Wiring/Sealing Austin Healey 1
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
T TR6 TR6 Carb Gasket Sealing Triumph 1
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
nichola TR6 Classic Technologies front sealing block Triumph 7
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
BN6_2197 Sealing my legroom Austin Healey 11
G TR2/3/3A sealing body seams? Triumph 12
B General Tech Wire wheel sealing bands? MG 4
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
M TR6 Front sealing block Triumph 11
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
T TR2/3/3A TR-4 Sealing Block Triumph 2
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
S TR2/3/3A Wire Wheels Sealing Triumph 17
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
R removing black seam sealing Austin Healey 3
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
TRMark Being my own DPO, stripped front sealing block Triumph 6
Nelson Sealing exhaust pipe junction Spridgets 14
KVH TR4/4A TR4 Front Sealing Block Triumph 2
I Sealing new outer panels on BN1 Austin Healey 10
T sealing oil leaks in a horizontal joint Spridgets 6
O TR2/3/3A TR3 Winshield Sealing Triumph 9
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
A Sealing exhaust leak - help! Triumph 20
S sealing shim pack Triumph 2
Brosky Sealing blocks are available again Triumph 5
LastDeadLast Brosky - Front sealing block info? Triumph 15
I Bugeye gas tank sealing ring help Spridgets 2
MTribe special bolt for copper washer on sealing block? Triumph 2
Brosky Sealing of Saddle Block in front of engine Triumph 7
steveg Rear Engine Plate sealing question Austin Healey 8
B Sealing block and good thrust washers Triumph 5
J What kind of compound to use as wing2body sealing Triumph 6
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
PATR8 Windshield sealing Triumph 2
Nunyas Sealing a vented oil fill cap MG 6
Ed_K Sealing the gear carrier to the rear axle case ? Austin Healey 8
G Sealing Block Triumph 6
cdsmith "sealing" gas tank sending unit Spridgets 8
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
tr6web Sealing, lubes, etc. Triumph 8
L Removing Master Cylinder Without Paint Damage Austin Healey 27
L TRW-Lucas Brand Master Cylinders Austin Healey 2
