Sealing of Saddle Block in front of engine
Brosky
There was a question on another of my rebuilding threads that I felt rated it's own answer. I stopped at Her Majesty's this morning to see exactly what was on the Payen lower end gasket set and was surprised at what I saw.
The Payen set now uses a rubber, or most likely neoprene wedges to replace the wood. They are a bit of a pain to get in, but look like a really good seal when combined with the Goldblatt steel block. :square:
And don't forget the position of the two side gaskets (under the block) in relation to the tangs facing forward. :laugh:
Tom74TR6
Yes, much nicer - the tree that was saved for the wedges will be used later when I print these photos and hang them next to my block so I don't forget anything.
Thanks Paul
70herald
I am not so sure that that is in fact a great improvement. The wood blocks swell up when exposed to oil and will seal very tight even if they are slightly damaged when installing them. If there is any damage to those rubber blocks, they are going to leak.
I took several engines apart to get a good supply of bits for the Herald and the wooden sealing blocks were very tight in all of them.
The problem with the saddle block leaking was never related to the wooden blocks it was almost always a result of someone stripping out the threads.
billspit
I got the rubber ones with my Payen kit. Unfortunately I had already installed the saddle block and could not get them to go in after the fact. I had to use wooden ones.
Flinkly
at first i was suprised to see wood blocks used in engine design, but now i like them. makes the whole car feel more rustic. then again, i've got a completly stock engine. keep up the good work.
also, all these pictures and info (and maybe even a bit more) will be on your website after you get done putting the "necessary" miles on your engine, right?
Brosky
Brosky
These are a very tight fit, trust me on that. If Erik is happy with them, after all of the TR6 engines that he's built, they're fine with me.
Flinky, I'm probably going to add two pages to my website. One for the engine machining and one for this assembly and quirky stuff. Who knows, maybe more, since these projects take on a life of their own.
B Steering Column Wiring/Sealing Austin Healey 1
D TR2/3/3A sealing master cylinder pocket Triumph 8
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
T TR6 TR6 Carb Gasket Sealing Triumph 1
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
nichola TR6 Classic Technologies front sealing block Triumph 7
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
BN6_2197 Sealing my legroom Austin Healey 11
G TR2/3/3A sealing body seams? Triumph 12
B General Tech Wire wheel sealing bands? MG 4
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
M TR6 Front sealing block Triumph 11
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
T TR2/3/3A TR-4 Sealing Block Triumph 2
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
S TR2/3/3A Wire Wheels Sealing Triumph 17
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
R removing black seam sealing Austin Healey 3
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
TRMark Being my own DPO, stripped front sealing block Triumph 6
Nelson Sealing exhaust pipe junction Spridgets 14
KVH TR4/4A TR4 Front Sealing Block Triumph 2
I Sealing new outer panels on BN1 Austin Healey 10
T sealing oil leaks in a horizontal joint Spridgets 6
O TR2/3/3A TR3 Winshield Sealing Triumph 9
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
A Sealing exhaust leak - help! Triumph 20
S sealing shim pack Triumph 2
Brosky Sealing blocks are available again Triumph 5
LastDeadLast Brosky - Front sealing block info? Triumph 15
I Bugeye gas tank sealing ring help Spridgets 2
MTribe special bolt for copper washer on sealing block? Triumph 2
steveg Rear Engine Plate sealing question Austin Healey 8
B Sealing block and good thrust washers Triumph 5
J What kind of compound to use as wing2body sealing Triumph 6
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
PATR8 Windshield sealing Triumph 2
Nunyas Sealing a vented oil fill cap MG 6
Ed_K Sealing the gear carrier to the rear axle case ? Austin Healey 8
G Sealing Block Triumph 6
cdsmith "sealing" gas tank sending unit Spridgets 8
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
tr6web Sealing, lubes, etc. Triumph 8
M Back In The Saddle [almost] Spridgets 6
davidk Stripped threads in oil pan front saddle block Triumph 12
2wrench Back in the saddle with timing gear questions. Triumph 9
