Bugeye gas tank sealing ring help
ichthos
I just wanted to double check this - does the doughnut seal go between the bottom of the car and the gas tank?
Thanks,
Kevin
jlaird
Yep, that's the place.
X gas tank strainer in Bugeye Spridgets 6
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
I Bugeye gas tank bolts Spridgets 1
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
drooartz Coating a Bugeye gas tank Spridgets 5
tony barnhill jlaird - Bugeye Gas Tank Spridgets 1
I Bugeye gas line help Spridgets 4
Rut Bugeye bonnet gas struts Spridgets 6
P After market gas tanks for bugeye Spridgets 4
I Bugeye gas gauge Spridgets 4
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
bcbug Bugeye gas pedal Spridgets 6
T Pictures of Bugeye gas pedal and linkage Spridgets 2
jlaird A really accurate gas gauge, Bugeye Spridgets 7
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
