Bugeye gas gauge
ichthos
Still working out the bugs in my newly restored bugeye. I noticed that the gas gauge tends to move around. For instance, when I was driving yesterday, it moved down to 1/4. When I stopped and started it again, it went back up to 1/2. Is this just a grounding problem, or do I need to have it worked on? If I do get it worked on, any suggestions on who I should send it to?
Kevin
smaceng
Kevin, all the BE gas guages do that. The gas guage is just an indicator of how much gas is left. The real test is when it stops on the side of the road!
Scott in CA
Sarastro
Yeah, it's an early digital gauge: full or empty.
Problem is, there is no damping in the gauge, so anything that affects the sensed fuel level makes the gauge reading change. Like the fuel slopping around in the tank when you start and stop, or stopping on a hill.
Fuel gauges of that era were notoriously inaccurate, at best. Even today they're not great.
Rut
That's not too bad, my GMC pickup drops to empty when I stop for a light no matter how full, moves back up when the truck moves...weird.
Rut
regularman
Probably 3 things cause it to move. One is the gas sloshing around in there and changing the level where the gauge is when you start, stop, go uphill, etc. The second is any looseness in hinges of the float. The third is that is a 12 volt sourced gauge and the voltage of the generator models might be 10-16 volts at any given time depending if its a idle or revved and what lights you have turned on.
Still you can get them pretty accurate. If you want to calibrate the sender to the gauge, I can tell you how I do it. Does your tank have a drain?
BugeyeNJ58 Gas Gauge Broken on '58 Bugeye.?? Spridgets 9
jlaird A really accurate gas gauge, Bugeye Spridgets 7
I Bugeye gas line help Spridgets 4
Rut Bugeye bonnet gas struts Spridgets 6
P After market gas tanks for bugeye Spridgets 4
X gas tank strainer in Bugeye Spridgets 6
E Bugeye Gas Tank Filler Tube Grommet Spridgets 13
bcbug Bugeye gas pedal Spridgets 6
I Bugeye gas tank bolts Spridgets 1
T Pictures of Bugeye gas pedal and linkage Spridgets 2
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
I Bugeye gas tank sealing ring help Spridgets 2
drooartz Coating a Bugeye gas tank Spridgets 5
tony barnhill jlaird - Bugeye Gas Tank Spridgets 1
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
drooartz Replacing Bugeye windshield rubber Spridgets 6
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
D Wanted Bugeye bonnet (hood) fiberglass or steel Austin Healey Classifieds 0
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
drooartz Restoring Penny the Bugeye Spridgets 22
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
R Bugeye Starter Switch Spridgets 7
Lin Bugeye Axle Hub & Bearings Austin Healey 1
G For Sale 1960 BugEye..Very Good..$20,500 Austin Healey Classifieds 0
Lou E Finally a Bugeye of my very own Spridgets 41
5 Sold My 1960 Bugeye Spridgets 10
SNClocks Goings on with our new Bugeye Spridgets 1
F 59 bugeye spring bushing bolt Spridgets 8
Rut 3 point belts in a Bugeye? Spridgets 9
JPSmit gluing a panel on to a bugeye Restoration & Tools 2
I Bugeye oil leak help Spridgets 4
I Bugeye lack of power Spridgets 1
