BugeyeNJ58
Problem: Gas gauge always at "E". (Gas is positive ground)
From what I've researched, and read on this site, the gauge doesn't have a voltage stabilizer. I have a green wire in the back of the Bugeye -it wasn't connected. I ran a wire from that and attached it to the post labeled "T" on the gauge. I attached a hot wire to the post labeled "B", and attached a good ground to the center screw that is used for attaching the bracket to the instrument to keep iton the dash.
Turn key on, gauge still at E (all the way). I have another wire going to a good ground, when I touch it to the "T" post, gauge goes all way to F.
Does this indicate that the sending unit from the tank is bad?
thanks....
thanks....
