MGB Replaced sending gas gauge unit.
PAUL161
Not that it's a very interesting subject, but I replaced the fuel sending unit on the 72B. The gauge quit working, so a new one was ordered and I put it in yesterday. Found the one I took out, which was only 6 years old, had a crack in it's plastic float and was full of gas. Found that the sender is still good, just in need of a float. Another spare part for the bin. That float should not have gone bad in that short of a time! Oh well, nothing new there.
I did take it out for a 20 mile run and the car preformed flawlessly! PJ
Platinum
Not sure if we could blame ethanol or P-Poor quality materials... but my take is it'll be a bit of both.
drooartz
Hey, at least it was a nice, simple fix. I like those. :smile:
PAUL161
PAUL161
Bad thing about all of this is, the prices of these parts keep going up but the quality keeps going down! Electronics seem to be holding their own though, actually getting better in some stuff. :encouragement: PJ
I had the same thing happen to mine. Tried to find the brass Ford version of the float but no luck. Drilled a tiny hole where the crack was, drained the gas and filled the crack/hole with a fuel resistant glue from the hardware store and worked fine ever since.
PAUL161
PAUL161
The crack in this float is in the grove where the wire arm snaps in. It could be repaired with a high tech glue, but I would only do that in an emergency where a new one was not available. I think I have a copper float in one of the drawers and I'll probably repair it with that. PJ
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
Basil Replaced Telluride Reverse lights w/ LEDs Other Cars 7
T 66 Austin Healey fuel pump replaced Austin Healey 30
KVH TR4/4A I Replaced the Cam Bearings Triumph 19
H Windshield Post to Body - Captive nut needs to be replaced - Pillar to Body Spridgets 2
M Brake fluid on tire - cylinder need replaced? Spridgets 19
G Brake/clutch resevoid replaced do I have to bleed the system Austin Healey 9
johnrip Wedge TR7 had replaced rotors, now I have a noise and vibration-Wheel Bearing? Triumph 4
T GT6 These sills have been replaced, correct? Triumph 7
Michael Oritt WT/OP gauge replaced/plus a hose Austin Healey 0
B MGB 1972 MGB, Head Gasket replaced...runs very poorly. MG 30
B TR2/3/3A When you replaced your wiring harness [57 TR3] Triumph 5
M Replaced rear end, can't reconnect propshaft Spridgets 2
1 Rims need to be restored and/or replaced MG 19
jlaird Replaced that darn hose today Spridgets 0
Monark192 No Power - replaced coil, wires, rotor and cap MG 3
T TR2/3/3A Another TR3 battery box replaced Triumph 5
R 61 BT7 fuel tank needs to be replaced Austin Healey 14
RickB Replaced my alternator today. Spridgets 17
Randy Harris OT - Finally replaced my daily driver last week Austin Healey 11
T Should floor pan be replaced? MG 15
J has anyone ever replaced lower bushing in steering Triumph 5
Wana Anyone replaced heater control panel in BJ8? Austin Healey 3
S Wedge TR7 sender replaced...but still sweeps to hot Triumph 23
B General MG 77 MIDGET Gas tank sending unit MG 1
BoyRacer Fuel Tank Sending Unit Austin Healey 3
K TR2/3/3A Sending out SU's for throttle shaft rebushing........ Triumph 4
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
K TR2/3/3A Gas Gauge sending unit "float" orientation? Triumph 5
Joe Schlosser Bug Eye fuel gage sending unit Spridgets 15
S TR2/3/3A gauge sending unit Triumph 2
scottdr TR2/3/3A TR3 Fuel Sending Unit Triumph 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
R TR2/3/3A removing sending unit from tank of TR-3. Triumph 8
C Wanted Sunbeam Alpine 1, II Water Temp Electrical sending unit.[Or one that will work] Other British Classifieds 1
Got_All_4 TR2/3/3A Has anyone tried to rewind/fix a fuel tank sending unit? Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
D TR6 Oil sending light Triumph 10
TulsaFred Fuel Sending Unit Spridgets 4
George Zeck Sending Unit is toast ...... Spridgets 4
rjc157 fuel tank sending unit Austin Healey 4
R Fuel sending unit Austin Healey 4
V Fuel Gauge Sending Unit Austin Healey 3
B Sending Unit Adjustment? Spridgets 11
C TR2/3/3A fuel sending unit Triumph 9
D TR6 Oil sending switch Triumph 5
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
