Fuel Gauge Sending Unit
volts101
I have identified that my fuel sending unit is suspect on a 1967 BJ8.
It only gives 9 ohms with a full tank.
The gauge is OK and reads F with 70 ohms connected at the Sending unit.
Question is if the tank needs to be drained before changing the unit.... ??
Also is there any merit in opening the top cover (4 brass screws) to see if there is anything obvious to fix/fiddle with inside the unit ???
Bobbydsport
you don't have to empty the tank. I removed the 4 screws on my '67 BJ8 sending unit & removed it & then cleaned it with a q-tip & lacquer thinner. The only trouble was it still only registered 1/2 full when the tank was full. So I ordered a new one from a supplier & installed that one only to find the same reading at the gauge. Now I'm thinking the gauge needs to be re-calibrated.
Bobbyd
vette
you can move the magnets around on the back of the gauge to get it to read more accurately. I was able to get my gauge to read fairly accurately by just moving the magnets without the use of any external resistors or circuitry. I filled the tank and adjusted the magnets to just get the needle to go to full. Drove the car till I had a half tank verified by a wooden dip stick in the fill pipe. Then moved the magnets till the needle registered 1/2 tank. After about 2 more full tanks and some minor adjustments on the magnets the gauge was reading accurately.
BigGreen
... Question is if the tank needs to be drained before changing the unit.... ?? ...
No, but disconnect the battery to prevent sparks
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
6 Fuel gauge, sending unit, and tank compatibility Spridgets 9
G Fuel Gauge - Sending Unit Question Austin Healey 20
S TR2/3/3A Tr3 fuel gauge sending unit Triumph 6
C TR2/3/3A TR3 Fuel Gauge Sending Unit Triumph 2
J Fuel gauge sending unit Austin Healey 2
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
