Running out of fuel - gauge problem?
fishyboy
Hi all,
Yesterday I managed to run out of fuel in my BT7 for the first time in 26 years ownership (fortunately only mile from home). The fuel gauge read nearly "1/4" tank at the time. I had replaced the sender unit a couple of years back, but at the time did nothing to the gauge.
How can I get the gauge to read more correctly and prevent the long walk home to get get my fuel can? Do I somehow need to calibrate the gauge?
Thanks
Phil
PHulst
Bronze
Phil,
Did you put the sender in the correct direction?
Causal inspection makes one think that the float goes to the back, while in reality it should go towards the front. The previous owner of my 59 got this wrong, and carried a stick with him to check fuel levels after running out once.
I flipped the sender around and it now works perfectly.
Patrick
F
fishyboy
Hi all,
just took out the sender unit only to find the plastic float was half-full with petrol! The unit is only 2-3 years and has ruptured where gripped by the wire arm. Modern poor quality spares! I've put the old arm (55 years!) with a metal float back on a see how it gets on.
Phil
BJ8Healeys
If the float fills up with fuel, it should ride lower in the tank and therefore the gauge should display LESS fuel than you actually have unless the float is sticking against the tank structure. But I understand the crappy design of the wire arm and plastic float. Fourteen years ago I replaced my original sending unit because I discovered that the wiper of the rheostat appeared to be worn almost in two. The first replacement unit had the wire arm and plastic float, and it filled up with fuel within a month or so of installation because of a crack at the very end of the wire. The replacement I received for it actually had a HOLE where the sharp end of the arm gripped the float. I sent that one back, and in return received one whose rheostat wire was wound so poorly that the gauge was so erratic as to be useless. The problem with the float is obvious: the end of the wire is sheared off in manufacture to leave a sharp edge that bites into the plastic. I would have thought by now that that problem would have been recognized and solved, but perhaps some of the bad ones are still out there.
A substitute for the plastic float is a brass float made by Ford that is identical to the plastic one in dimensions. The Ford part number is COAZ-9202-B.
I filed the end of the wire smooth because a sharp wire might also cause a crack in the brass. However, deciding that the replacement sending units were too poorly manufactured and unreliable, I reinstalled my original unit and it has been working fine now since 2002, in spite of the worn wiper.
F
fishyboy
Thanks steve,
Yes your second sender is the same as my new one. Can't find the Ford float in the UK so ill see how the original one works out.
Phil
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
R GT6 Fuel issues - hard to keep running Triumph 26
drooartz Running fuel lines/electric pump Spridgets 20
T Running new fuel lines Triumph 7
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
D Rough running BT7 3 carb HELP Austin Healey 13
