running car on jack stands
equiprx
Not so much, unless at a slow rate.
equiprx
Only done it on car lift looking for EX leaks. I guess what is the reason is is up in the air PUNE
That's a different kettle of fish.
It would take more than one failure point to be disastrous.
Getting four jack stand to load equally is impossible.
equiprx
One option may be floor jack on dif and two back-up stands if jack leaks down.
Still extremely risky.
I would trust large wood blocks more.
LarryK
Never did it with anything bigger than a MK1 Spitfire.
LarryK
My stands are from the 50s, rock solid built right. Biught some new this year from BlackHawk 6000 lbs. each. I put a string on the coil wire in case something doesn't seem right to kill the engine.
Jim_Gruber
Consider removing tires to reduce vibration if you need to do this,
R
rossco
I probably won't do this. Never have and it doesn't seem to be something many do. Just getting feedback on what others think about it.
LarryK
I have not done this since the middle 70s. Ran a MK1 Spit out of gas to compare to gauge. Ran lots of stuff on lifts as it was safer.
Gliderman8
Be SMART, be SAFE…. Don’t do it.
LarryK
Never crawl under while running on stands, by might have someone watch ignition for killing motor. On lifts, someone in car while other cecks things out. How found bad crank sensors on the new 2005 Jags by squirting water on them.
LarryK
I would back in the cars into my srall that were stored over the winter. Jag V-12 shot dog food out both tailpipes. Stored in garage next to dog food wouldn't start and was towed in. Had a 36 Dodge that shot mice and babies at the wall. Bos came out and wondered what the popping noise was. I stayed late and repainted the wall.
bugedd Car running poorly Spridgets 7
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
mgbmedic car keeps running after pertronix install MG 11
sd80mac7204 How to turn a running car into yard art... Triumph 18
scoutll Car suddenly started running poorly Spridgets 17
D car will not stay running. MG 4
Ed_K If your car is running hot, get one of these ! Austin Healey 5
Brosky Sneak preview of Crypt Car running Triumph 15
N Car is running Triumph 13
V Car is running out of breath/ other simple probs. Triumph 4
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
