cpbol
I'm a new owner of an old Healey 3000 BJ8. When I took possession, it started and ran okay, but hadn't been freshened up in 10+ years. After a few short test rides, I discovered that the engine would sputter and nearly cut out after driving around town for about 10 minutes. It would run smooth as silk at first, which told me the carbs were tuned (well enough), but then after a few longer pulls through the gears, it would start to sputter and lose power, as if it were running out of gas. Long story long, this was repeatable many, many times. The fuel was fresh and I had plenty of fuel in the tank through all this.
1. My initial thought was to change the plug wires since they were old, and I could see visible corrosion under the 1 plug cap. Didn't fix the sputter.
2. Next, research showed that a bad coil can cause the symptoms. Easy to replace. Didn't fix the sputter.
3. Next I changed both fuel filters. One was before the fuel pump and the other was before the carbs. The one before the pump was packed full of crap. With clean filters, it didn't fix the sputter.
4. Next I cleaned out all 3 float bowls real well. Didn't fix the sputter.
5. Next, research showed the tank could be vacuum locked, so I loosened the gas cap when the sputter started. Didn't fix the sputter.
6. Next I changed the plugs, even though they weren't in bad shape. Didn't fix the sputter.
7. Next I checked the points. They were adjusted to the correct gap and were in really good condition.
Through all this I noticed that the fuel pump would pump away more frequently than I expected. My expectation was to hear it click maybe once every few seconds. There are times when I can hear it clicking steady and repeatedly - click, click, click, click. This weekend I discovered that I was able to keep it running fine by driving around like a Sunday driver - never really revving it up much in any gear. I have arrived to the conclusion that I must have a weak fuel pump. It clearly works well enough to stay running, but if I drive it any faster than an old lady drives, the fuel consumption seems to outrun the output of the pump, and it starts sputtering really bad. I have a new fuel pump on order that I will install later this week. My only other idea is an air leak somewhere. I checked the fitting at the tank and at both ports on the pump. There does not appear to be an air leak.
Am I missing any easy fixes?
