TR2/3/3A Fuel Gauge
Redoakboo
New starter, works great! Time to check other stuff before it hits the road.
My fuel gauge reads Full all the time. I fished a wire hook down around the float. I can pull it all the way above the gas level, still reads Full.
Does this indicate a bad sending unit, or gauge?
Dick
sp53
If it is the fuel gauge, it might be fixable, kinda easy, maybe. Anyways, there are adjusting screws on the outside back of the gauge for calibration that move these little coils inside the gauge and that could be waked out or over if you are lucky. Plus the connection oxidize easy, so if you have not had the gauge out of the car or loosened cleaned at the connections and retightened the problem could be anywhere in the loop.
CJD
The original TR2 used the steel fuel line to ground the gage. This system depends on having a braided fuel line from the fuel shutoff valve to the engine fuel pump. Most add a ground from the sender to the chassis, since the fuel valve is often removed and the hose changed to plain rubber, thus removing the factory ground. The TR3 used a separate ground from the sender tot he chassis.
sp53
Interesting the Tr2 did not have that little ground wire set up. They must have learned something about the gauge not grounding as they developed the car. It is basically a black wire with a big loop on one end to go under the gas tank strap, and I think the other end on the sender. I could see how with the wrong sealant on the gas tank sender unit, the sender itself could insulant and not work without some extra grounding.
Graham H
It is generally the gauge in the dash that has a poor earth, if it doesn't have one already fit a dedicated earth to the gauge .
Graham
mgedit
It is also possible that the sender and gauge are mismatched if someone has been working on these before. Cheers, Mike
sp53
I believe the tr2 is same as the early tr3 and is plumbed in with metal tubing. The early tr3 and tr2 had a braided line from the shut off to the pump. I have only seen one, but they are probably still listed. Most the time now that small section on the early stuff is rubber from the shut off to the pump. The braided line was probably deleted because of the fittings on the ends; they need to have 2 twistable ends. Most early cars still have metal out of the pump to the carbs on early cars. Around 1959- 60 they changed too more rubber line sections. There is a rubber line under the later cars connecting the 2 large lines together. Early cars are plumed in from tank to the shut off with metal.
Sarastro
I'll ask the obvious question that no one has asked yet: when you say "reads full all the time" does it read full even when the ignition is off? If so, it's the gauge. If only when the ignition is on, it could be either. It also might be that the wire from the gauge to the sensor is shorted to ground.
You can check the sender with an ohmmeter. The gauge is a little harder, but if the sender is OK and the wire is not shorted to ground (check that with an ohmmeter, too), it's gotta be the gauge. You can take it apart and you should see the problem easily.
CJD
Good call Steve. I was waiting for red to respond to the ground before bringing that up...
Graham H
The black wire on the left hand gauge is the earth, you need to make sure it has good contact otherwise when you turn on the ignition the needle will go straight to full and hit the stop pin.
Graham
R
Redoakboo
It has no grounding wire, think I will install one, per your pic. Is there a reason you installed the ground under the oil pressure bracket?
CJD
In that pic it is merely hanging loose at the end by the oil pressure gage. It should be grounded to the grounding stud on the panel.
Madflyer
Grounding is the number one reason. Gas lines are never a good ground as there has to be movement from the motor. TR's use a black wire as ground so grounding at gauges is needed even for one wire gauge lite. A bad sending unit would be one of two things 1 a bad float 2 a open resistor on sending unit. A hot feed through gauge to resistor to ground to get reading. A tap of the gauge as needle may be stuck. Madflyer
Graham H
It was back in 2011 when I did the rebuild so I can't remember all the details. I am sure it was connected to the grounding stud on the panel, it's defiantly not under the oil pressure mounting bracket. You could use a temporary earth wire with an alligator clip on one end clipped to the mounting stud to see if that solves your problem and as Madflyer said tap the gauge with ignition off as the needle may be stuck.
Graham
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
N Spitfire Fuel gauge Triumph 8
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
Rut Bugeye fuel gauge Spridgets 14
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
