TR2/3/3A Can a TR4A fuel gauge be used in a 3A?
trrdster2000
Sure, just a couple of things. Do you have a voltage stabilizer or can you get one, it will read high otherwise and will look a little out of place, just use your convex lens and all will be fine.
I have a full set of gauges somewhere, I know the temp is broken, but could be a good buy for someone, they have the convex lenses.
Would not break the set for one gauge and surely there are a lot of them floating around.
Good luck. Wayne
TR3driver
Great Pumpkin - R.I.P
You'd have to use the 4A sender as well. The tr3 sender works backwards to the later ones.
trrdster2000
Good point, I did not know that.
Could the wires be reversed at the gauge?
Wayne
TR3driver
Wouldn't fix the problem. The TR3 sender gives a low resistance for empty, while the TR4A gauge will show full for a low resistance.
Basically, the gauge went from being magnetic to thermal when the TR4 was introduced.
trrdster2000
That kind of takes care of the swop.
Karl, if you go the route and need a sending unit, I'm sure I have a couple, they do have the plastic floats with them. Seems like a lot of trouble, but you do what you have to, sometimes.
Wayne
K
karls59tr
Bronze
I'm still in the process of finding out why the fuel gauge needle dosn't move when I turn on the ignition (1/2 tank of fuel) before I go the 4A gauge route but thanks for the sender offer. I might try the test that Randall posted recently to see if I can get the original to work. I put a new wiring harness in the 3 and everything works great but the fuel gauge. Haven't had a working fuel gauge for close to 20 years.lol
trrdster2000
Understand, the '37 had its own stick with marks for how much. LOL
Wayne
6TTR3A
90% of sidescreen fuel gauge problems are poor or nonresistant grounds. The factory provided the ground thru the fuel gauge attachment bracket, which seldom if ever was adequate. The fix is a dedicated ground. Clip a test lead to the fuel gauge stud, ground the other end anywhere. If it works, make it permanent. Also, a properly installed fuel tank is not grounded. Be sure there is a wire running from the tank sending unit to ground.
Frank
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
KVH TR4/4A Fuel Gauge TR4A Triumph 18
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
D TR4/4A TR4A clogged fuel filter Triumph 13
Zimmycobra For Sale Original 1966 TR4A Fuel Tank Triumph Classifieds 0
R TR4/4A Tr4a fuel cap o'ring Triumph 7
R TR4/4A Corbin clamps of fuel lines Tr4a Triumph 5
R TR4/4A restored my tr4a fuel tank Triumph 1
T TR4/4A Close up pics of your TR4a fuel lines Triumph 5
T TR4/4A Paint color for engine bay fuel lines TR4a Triumph 4
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
Stinger TR4/4A TR4A Fuel Pump Question Triumph 2
RJS TR4/4A TR4A Fuel Pump Removal Triumph 9
CinneaghTR TR4/4A TR4A Fuel and Brake Line Routing and Dual Exhaust Triumph 6
Stinger TR4/4A TR4A Fuel Pump Leak Triumph 6
R TR4/4A TR4a fuel line, new Triumph 6
P TR4/4A TR4A Electric Fuel Pump Installation Triumph 7
T TR4/4A TR4A Fuel Starvation problem: Dry float bowls Triumph 8
R TR4/4A TR4A copper fuel line kits Victoria British Triumph 4
KVH TR4/4A TR4A Fuel Pump Problem? Triumph 4
dklawson TR4/4A TR4-TR4A Fuel Sender Resistance? Triumph 3
W TR4/4A TR4A fuel starvation. Triumph 4
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
DocDup1 TR4/4A TR4A Wiper Moror Rebuild Service Triumph 5
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
Popeye TR4/4A TR4A Assembly by a rookie (me!) Triumph 149
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
Sarastro TR4/4A Another 50K TR4A Triumph 5
DocDup1 Wanted TR4A Accelerator Linkage Lever Triumph Classifieds 0
J TR4/4A TR4A seat retaining clip Triumph 5
Carlos Trade Free for the cost of shipping TR4A radiator Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
