Spitfire Fuel gauge
number6
Since I got my Spitfire ( Sabrina ) I have had a consistently low reading fuel gauge. Full tank, gauge reads just below 3/4 full. So far I have replaced the gauge 3 times, swapped
The voltage regulator and inspected the fuel float, which is intact. Float arm is free and has full range of motion. Grounded the sender wire and still get the same result. I am beginning to believe that the wire between the tank and gauge has an issue. Thoughts and suggestions would be welcome at this point. Next step I guess would be to run a new wire between
and see if that makes a difference. Not a big deal really, but one of those small things that bothers me.
Gliderman8
Did you check to make sure the float doesn't have fuel in it?
Over time the plastic floats can leak.
TR3driver
Great Pumpkin - R.I.P
What happens if you ground the wire to the sender at the gauge? If that takes it to full scale (note that it takes some time for the gauge to fully respond), then there is likely a problem with the wiree to the sender. Otherwise, I would guess a problem with the wire to the VS. Check the power right at the gauge if you can.
N
number6
I appreciate the suggestions and will try them. The float is completely empty. I'll give the results as soon
as I can get back to car.
Thank you, Tom.
dklawson
With the Spitfire, you can remove the sending unit from the tank and leave its wires connected. With the ignition on, move the float arm slowly through its full range of motion. If you move the arm all the way "up" does the gauge go to "full"? If not, disconnect the two wires and with the arm fully up, measure the resistance across the two sending unit terminals. When the arm is fully up the resistance should be close to 30 Ohms.
Let us know what you find doing these tests and the others suggested above.
N
number6
Andrew, interesting observation, I hadn't been taking notice of the temp gauge. But it does read slightly higher with the different stabilizer. I did ground the wire at the gauge and needle did go almost all the way to full. Both of the stabilizers were ones I had kicking around, sooo, I am going to order a new one. Since I am in the middle of this I think it would probably be a good idea to replace the sender
as well. Stay tuned for more, same bat time, same bat channel.
dklawson
Do not spend money on a new stabilizer yet unless you just want to have a more modern one.
If both fuel and temp gauges were reading high, or both were reading low, that suggests looking at the voltage stabilizer. However, in your case, with one gauge reading high and one reading low, that suggests a problem with the sending units or gauges... not the stabilizer.
N
number6
It's reading closer to full than it was, I can live with that. Appreciate all the hints I have been given. Thank you, everyone. Always good to have extra insight.
Tom s
G MGB ugh.....the fuel gauge went to *** again! MG 8
roscoe Fuel Gauge Austin Healey 0
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
Fanch00 Inoperative Fuel Gauge Austin Healey 10
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
R TR2/3/3A Fuel Gauge Triumph 19
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A Fuel gauge readings? Triumph 12
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
K TR2/3/3A Re TR4 and TR3 fuel gauge sending units again.... Triumph 0
K TR2/3/3A Can a TR4A Fuel Gauge be swapped into a TR3A? Triumph 8
K TR2/3/3A Fuel Gauge again.... Triumph 11
N Fuel gauge problems? Spridgets 9
warwick-steve Fuel Gauge always shows 1/4 full Austin Healey 27
N Fuel gauge problem's? Spridgets 4
D Wanted TR3A Fuel gauge Triumph Classifieds 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
Lutz Kramer Fuel gauge and sender unit for BJ8 Austin Healey 2
George Zeck Looking for a fuel gauge ...... Spridgets 2
S Fuel Gauge Question Austin Healey 8
K For Sale TR3 Fuel Gauge Triumph Classifieds 8
warwick-steve Fuel Gauge always indicates 1/4 full. Austin Healey 13
J Fuel sender, fuel gauge 100 4 Austin Healey 6
George Zeck What fuel gauge SHOULD I have? Spridgets 3
sim 1958 fuel gauge sprite Spridgets 11
Martinld123 Austin Healey 100 BN2 fuel gauge not working Austin Healey 13
N Fuel gauge question?? Spridgets 3
B TR2/3/3A Fuel gauge problem Triumph 7
H TR2/3/3A Fuel sender or gauge? Triumph 8
F Running out of fuel - gauge problem? Austin Healey 5
K TR2/3/3A TR6 fuel gauge in a TR3? Triumph 1
K TR2/3/3A Fuel gauge and switching to Neg ground? Triumph 2
K TR2/3/3A Can a TR4A fuel gauge be used in a 3A? Triumph 8
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
Rut Bugeye fuel gauge Spridgets 14
Editor_Reid Fuel Gauge for 1967 Sprite Spridgets 4
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
