TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please
malbaby
Currently wiring to the above gauges, but not sure where the power wire from the voltage stabilizer goes to on each.
Gauges are in situ, so I cannot see if there are any markings on the back of the gauges.
Fuel gauge...power to empty side terminal. ??????
Temperature...power to high temp side terminal ????????
TR3driver
Great Pumpkin - R.I.P
Each gauge has two terminals on the back. One goes to the output of the voltage stabilizer, the other goes to the sender. Doesn't matter which one is which.
TR3driver
Yup. The active element inside this type of gauge is just a length of resistance wire, wound around a bimetallic strip. It doesn't care which way the current flows through the wire, which is why the same gauge (and connections) will work on either positive or negative ground. There are some nice photos of the workings at https://www.mgb-stuff.org.uk/fuel.htm
Ok, one caveat : I'm assuming you are talking about stock TR4 or TR4A gauges. Aftermarket gauges, even those made by Smiths, may be different.
Geo Hahn
Thanks TR3driver....Pardon me for saying this....are you absolutely sure.
Well, I know I smiled when I read that.
You've only been on the Forum for a year so you may not have noted a pattern. Randall doesn't know everything, but when he does offer an answer you can 'take it to the bank'.
TR3driver
Thanks for the vote of confidence Geo, but it's not strictly true. I do make mistakes just like everyone else; along with the occasional brain fart and senior moment.
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
S BJ7 frozen temperature sensor to block Austin Healey 17
K TR2/3/3A Temperature Gauges Again Triumph 5
S TR2/3/3A Temperature Guage Triumph 3
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
K TR2/3/3A Replacement Temperature Gauge Triumph 5
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
Dave Richards Temperature Guage Austin Healey 11
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Nelson "High" temperature adhesive Spridgets 7
L Temperature sensor relocation in BE with A 1275 Spridgets 8
Russ Austin Temperature gauge bulb stuck in thermost houseing! Triumph 10
