temperature gauge....HELP
Anthony_S
help me please....I started to remove my dash and gauges today and when I got to the temp gauge I could not get it out of the thermostat housing. Anyone have any ideas? I thought about cutting it, and replacing the whole gauge and back of the thermostat housing. Where would I get a new temp. gauge that is the same style as the original....would rather it didn't look too "new".
Thanks
Anthony
TR3driver
Great Pumpkin - R.I.P
Even if you cut the tubing, you'll still have to get the bulb out of the housing eventually (unless you replace the housing as well).
I don't know of a source for new gauges that match; but there are several places that will rebuild your old unit, including replacing the tube and bulb. Eg, Mo-Ma, West Valley, Nisongers to name just a few.
Another option might be the electric temp gauge from an early TR4. They are much more rugged than the mechanical TR3 gauges, and so turn up in good used condition from time to time. ISTR I paid about $30 for mine, plus another $30 or so for the sender and voltage stabilizer. The appearance is nearly identical, except the top number is 250F instead of 230F.
Anthony_S
Anthony_S
thanks, I will check out that thread. Worse case senerio was to cut the tubing and replace the housing, which I would rather not do but as of now thats my option cause I can't get the bulb out of the housing.
Thanks again.
Anthony_S
Anthony_S
Good thread, thanks :smile: I will have to try those things. Do you think it will help with the nut? I can't even get that thing to budge.
Thats cool our cars are that close :smile:
martx-5
Similar to the thread linked to. I had a stuck bulb and got it out by taking the housing off with the capillary tube still attached. You have to be careful that you don't mess up the tube or the bulb while working on getting it out of the housing. Have the nut unscrewed before you remove the housing. What I did was spray some of your favorite weasel wee (I used PB Blaster) both on the outside, and the inside where the bulb protrudes. Let it soak overnight, and you should be able to start wiggling the bulb out. You may need some more spray. You can also gently tap on it, which is what I had to do.
With a little patience, you can get it out.
TR3driver
Warming the housing will help with getting the nut loose, as the aluminum housing expands faster with heat than the steel nut. Don't go too far though, you don't want to ruin the gauge. Once you've given up and cut the tube, it doesn't matter.
6TTR3A
Take the time to remove the housing so you can work from both sides. The cost of a temp gauge rebuild is a lot more than some gaskets, antifreeze, PB blaster and/or Lime Away
Anthony_S
Anthony_S
Well thanks for all the input on this too. I tried all of these things and to no avail it isn't budging :frown: I gave up and decided to cut the tubing so I can continue on. I will be looking into sending the gauge to someone to rebuild it. I am hoping I will be able to get the nut and bulb out so I don't have to buy a new rear housing but we will see I guess.
Anthony_S
Anthony_S
Just wanted to let ya'll know I got the bolt out of the housing last night. Now I just need to get the bulb out and I won't have to replace the housing too. Baby steps that put a smile on my face :smile:
TR3TomG
I had a line break in my MGTF temp gauge and just had Nisongers fix it(same type set up with the cap tube and line) and they did a beautiful job. I thik it cost $130. Down side is that it took 4 weeks. Anyway, when the line broke on my TR3, I picked up a used one on Ebay for a little over $100 and it has worked just fine (and I then sold the busted one for about half that).
If you have not gotten the bulb out, you may want to try ATF fluid and Acetone mixed 50/50 and let it soak. There are other things you can use, but this seems to be what a lot folks recommend as a penetrating sollution for stuck parts.
Best of luck.
Anthony_S
Anthony_S
Yeah I have it soaking in Limeaway right now, I also have PB blaster and CLR. I did find a gauge on ebay for 70 bucks so Im excited about that. It is a clone but better than paying double to have mine rebuilt. What is ATF fluid?
TR3TomG
ATF = Automatic Transmission Fluid. I have seen the clones on Ebay, and they seem to look fine, though I dont know anything about how well they work. Just be sure that the one you are buying works. Soak the bulb in hot water before installing to insure the needle moves up.
Anthony_S
Anthony_S
Thanks, I feel silly now asking about ATF haha. This guy had 100% positive feed back on all he has sold. But I will be sure to check it out. He even said send it back if it doesn't work and he would refund.
DNK
They did my tach when I had it changed over to electric.
They called and let me know what they were going to do and how much before they did it.
Was very satisfied with the customer service
martx-5
Anthony_S said:
... I did find a gauge on ebay for 70 bucks so Im excited about that. It is a clone but better than paying double to have mine rebuilt.
I bought one of those clones, and the look of it is very, very close to original. The big difference is in how it illuminated. You'll have to run a separate bulb that fits inside the housing.
I haven't installed it yet, as I have a cheap FLAPS unit in there now.
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
BierRunner TR6 Temperature Gauge Triumph 8
R Coolant temperature gauge Spridgets 8
B TR2/3/3A TR3 Temperature gauge Triumph 19
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Replacement Temperature Gauge Triumph 5
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Russ Austin Temperature gauge bulb stuck in thermost houseing! Triumph 10
L TR2/3/3A TR3A - measuring operating temperature w/o gauge? Triumph 12
K Smiths Electric Temperature Gauge Triumph 7
Tinkerman TR2/3/3A TR3A Temperature gauge capilliary tube routing. Triumph 0
W TR2/3/3A Temperature Gauge Rebuild TR3 Triumph 19
MGTF1250Dave TR2/3/3A TR3 Temperature Gauge Face Markings Triumph 3
A TR2/3/3A NOS TR3 Temperature Gauge Triumph 8
RandallRK Temperature Gauge reading Austin Healey 2
regularman Temperature gauge Spridgets 13
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
H TR2/3/3A TR3 Temperature gauge Triumph 23
Brooklands TR2/3/3A TR3 Temperature Gauge Triumph 38
T TR2/3/3A Trouble shooting TR3a Temperature gauge Triumph 13
Russ Austin Temperature gauge went goofy!! Triumph 37
TR4 Temperature Gauge Issue Triumph 8
C Temperature Gauge MG 23
D TR4/4A tr4 temperature gauge/sensor reading Triumph 11
fmichaels temperature gauge question Spridgets 6
Trevor Jessie Driving without temperature gauge Spridgets 8
W Temperature Gauge calibration Triumph 4
Dugger Temperature gauge Triumph 4
R "wonkey" Temperature Gauge Austin Healey 6
S TR2/3/3A Tr3 temperature gauge route Triumph 12
Webb Sledge TR6 TR6 Temperature Gauge Triumph 19
G New member with temperature gauge question MG 5
MGTF1250Dave Water Temperature Gauge Triumph 2
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
