is it posible to fit an electric temperature gauge ?
Jer
Greetings
"Life" has finally slowed to a point where I have been able to repair my overheated 74 Midget, I blew the bulb right off the capilary tube & I'm looking into a "plan B" if I can't repair it, I'm sure the fittings are a special thread but is there any way to adapt an after market electrical temp gauge to the fitting on the 1275 motor ? I searched & see lots of info on repairing & replacing, but I can't afford the 200 bucks for a new one right now & if I can't fix it... I still would like to drive it :smile:
Thanks in advance
A $20 gauge from autozone will fit it.
Jer
Jer
Great ! Thanks... didn't think it would be that easy !
Jer
Jer
The temp gauge / sender I got had a 1/8 npt sender & that wouldn't fit right in (what do you expect for 9 bucks on Amazon lol), so I cut the old packing nut out from the capillary tube & drilled & tapped the ID to 1/8 NPT - That worked just fine !, compared gauge to my temp gun & it was bang on - Good to Go !
dklawson
DIY repair of capillary tube temperature gauges is linked below:
https://www.ply33.com/Repair/tempgauge
It works. However, substitute dry ice for the water/salt chilling bath. It's colder and cleaner.
Like Jer, I have made sending unit adapters by drilling out and tapping old temperature gauge nuts and old electrical sending units. For future reference, the temperature sender tap in the A-series heads is 5/8-18. However, the sending units don't seal on their threads, they seal on the conical seat at the bottom of the tapped hole. Teflon tape is your friend.
Simmo MGB Will Wings (Mud Guards) fit? MG 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D TR2/3/3A Windshield glass doesn't fit Triumph 6
M Which wires fit which terminals on my Rover V8 ignition switch? Rover / Land Rover 6
jehuie Where to post for parts that fit many cars? FORUM Navigation Questions 1
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
KVH General Tech Grant Piston Rings--Can't Fit Them Triumph 15
R Wire Wheel Fit Austin Healey 10
D Door Seal Fit Austin Healey 18
R BUGEYE SOFT TOP FIT Spridgets 2
algot1901 How did people in the 1950's manage to fit in the Prefect???? Other British Cars 16
chicken BJ7 Door Fit Austin Healey 27
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
S Rear Wing Fit Austin Healey 4
69MGC MGC What size tires will fit nicely MG 2
J Top Trunnion Bushing Fit Austin Healey 9
M TR4/4A Do MGF seats fit in TR4 Triumph 0
P Seat Bottoms And Bases Don't Seem To fit Together Well Austin Healey 4
K TR2/3/3A Control hedd fit? Triumph 1
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
S TR2/3/3A tr3 spare tire fit Triumph 16
T XK120 fit 140 rack & pinion Jaguar 3
L TR2/3/3A Liner spigot fit? Triumph 13
hondo402000 TR6 TR6 Windscreen remove and now windows dont fit Triumph 3
P top frame fit Spridgets 5
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
AngliaGT Rubber Gasket - What's it Fit? British Motor Corp 3
anarchy99 Bonnet / hood fit question... Spridgets 2
G General Tech Have new blank key for TR3 but cannot get it "cut" to fit ignition. Triumph 14
P Question about BJ7 Shut Face Finisher Fit Austin Healey 3
TulsaFred New Bugeye Seat Covers from AH Spares don't seem to fit properly Spridgets 10
D TR2/3/3A Gas tank does not fit! Triumph 4
FredApplerot For Sale Free: Midget sun visors to fit 1977-80 Spridgets Classified 1
Jim_Stevens TR2/3/3A TRF panel fit? Triumph 5
Sarastro TR4/4A New pinion seal doesn't fit! Triumph 20
Got_All_4 TR2/3/3A Beauty Rings Don't Fit Triumph 22
S TR4/4A windshield glazing rubberand trim fit Triumph 3
T Front Tilt or Stock Fit Bonnet Spridgets 18
S TR4/4A How to fit exhaust intermediate pipe? Triumph 5
RJS General TR Head Gasket Test Fit Triumph 5
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
R Wanted looking for original seats to fit my 61 bugeye sprite Austin Healey Classifieds 5
chicken Healey BJ7 inner door panel fit Austin Healey 7
Csarneson Old Engine - Journals don't fit? Austin Healey 2
Alfred E. Neuman MGA Question for the MGA coupe owners - will I fit? MG 8
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
S Question: Works Vent, how to fit Austin Healey 0
roysimpsonjr TR4/4A Will an 8 inch wide radio fit? Triumph 3
Popeye TR4/4A TR4A front frame reinforcement / parts don't fit Triumph 6
