TR4/4A TR4A front frame reinforcement / parts don't fit
Popeye
Bronze
I hope all are enjoying a fabulous 4th of July!
I am rebuilding my TR4A, and am working on the frame and front suspension.
I bought the front suspension frame reinforcement kit, and welded the bits on. (TRF p/n RFK158 - not endorsing TRF, just identifying exactly what I've done.) Then I had my frame blasted and primed while I replaced all the bushings in my front suspension with the TRF magic kit.
And now... things don't fit anymore. The front-most reinforcement bracket that I welded in place interferes with the bolt head from the front lower wishbone. See photos for details. The photos are all passenger side, and the interference is the front-most bracket. The rear wishbone will fit, no problem.
1. Did I install the frame reinforcement kit correctly? One bracket was on the original TR4A frame, and I welded on three more. Should the front-most bracket not have been installed?
2. How do I fix this... should I just cut a diagonal to allow the bolt head clearance, or should I remove the entire reinforcement?
Darrell_Walker
When I installed the kit (quite some time ago), there were two different sized reinforcements. Are yours both the same size? I'll see if I can get pictures, not sure now visible it will be with everything in place.
Darrell_Walker
OK, hopefully you can see something in these. This is the drivers's side, looking down from inside the engine compartment. On the rear mount, hopefully you can see the shorter reinforcement toward the front. On the front attachment, the reinforcement is only on the rear of the bracket.
Popeye
Popeye
Bronze
The kit had one short and two tall brackets (per side). The short one I put on the rear (and that works well), and the two tall ones I put on the front. Which is where the problem is... did I put the wrong one in the wrong location?
Popeye
Popeye
Bronze
Thank you! I really appreciate the photos! I did the same - almost - as I put two on the front and I think that is the mistake. I guess ill make a cut to allow room for the bolt.
BL50
Bronze
I used the same kit from TRF and had to cut them down to make them fit. I was going to complain to TRF but never got around to it. I'd post a few pics but I'm away from my TR project for a couple weeks.
Popeye
Popeye
Bronze
Cut and done! Thanks for the feedback and advice from the community, as always!
(Note - BL50, the kit TRF sells is the same as the others. I presume it is a "generic" kit for all frames, thus perhaps for the 4A there are some extra bits, or bits that need trimming.)
I present you, a one-legged Triumph:
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
Popeye TR4/4A Latest thoughts on TR4A front springs? Triumph 8
Popeye TR4/4A TR4A rear tub repairs (likely accident damage in front of rear wheels) Triumph 6
M Wanted Wanted TR4A/TR250 passenger side front fender Triumph Classifieds 0
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
Popeye TR4/4A TR4A front suspension quesions Triumph 19
T TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question. Triumph 1
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M TR4/4A TR4A & 250 front bumper guards Triumph 5
GlennG TR4/4A TR4A Front Valances - How do they fit? Triumph 3
fpstude TR4/4A Front lower suspension brackets - TR4A Triumph 14
J TR4/4A TR4A Front Suspension reinforcement brackets Triumph 4
T TR4/4A TR4A - grille to front valence Triumph 3
M TR4/4A TR4A Front Suspension Bracket Triumph 3
KVH TR4/4A TR4A IRS Front and Rear Differential Bridge Pins Triumph 6
glemon TR5/TR250 Lowering TR4A/250/6 in the front Triumph 13
R TR4/4A Disc wheel studs front and rear TR4a irs Triumph 4
Stinger TR4/4A TR4A Front Badge Quality Triumph 6
Darrell_Walker TR4/4A TR4A front sidelamp trim ring Triumph 4
Stinger TR4/4A TR4A Front Lower Valance Panel Triumph 2
Zimmycobra TR4/4A TR4A Front ride height revisited Triumph 24
Stinger TR4/4A TR4A Front Suspension Rebuild Triumph 26
KVH TR4/4A TR4A Front Suspension Triumph 2
T TR4/4A Once more - with feeling - Tr4a front suspension Triumph 10
T TR4/4A Correct front radiator tray for TR4a sway bar? Triumph 6
R TR4/4A TR4A Front lower Apron Triumph 2
T TR4/4A TR4A front rotor questions Triumph 11
T TR4/4A Removing TR4a front rotors Triumph 5
R TR4/4A TR4A Front Coil Spring Replacement Triumph 8
T TR4/4A TR4A front floor - patch or bolt new ones on? Triumph 3
L TR4/4A 66 tr4a front caliper rebuild...tips? Triumph 4
WME TR4/4A TR4A Front and Rear Shock Part Numbers Triumph 1
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
G Wanted Tr4a boot lid Triumph Classifieds 2
J TR4/4A TR4A automatic transmission conversion Triumph 6
D TR4/4A TR4a Fuel Pump Triumph 10
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T Wanted TR4A hardtop Triumph Classifieds 2
KVH General Tech Improvement to TR4A Muffler Triumph 1
KVH General Tech TR4A Brake Bleeding Triumph 5
KVH General Tech Reinstalling TR4A Interior Triumph 13
KVH General Tech Yes, the Horns Again--Electrical TR4A Triumph 8
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
KVH General Tech New Clutch Installation--TR4A Triumph 5
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
2 Wanted Wanted - TR4A parts engine Triumph Classifieds 2
