TR4/4A Who is running Good Parts front springs on their TR4a? I have a ride height question.
tdskip
Hi guys - I want to bring the ride height down on the front of my TR4a and I know some people have used the Good Parts TR6 springs. Any pictures on where that put your front suspension? Any tips or coaching having been there and done that?
Thanks!
JerryVV
Been there and done that, send me your e-mail address and I'll send some photos. Keep in mind that you will need to find a way to get the correct negative camber once you lower the front (or back for that matter) and in the case of the front you need to adjust the upper A-Arms somehow to get the correct alignment. If you do the rear (and you should or you'll end up with significant California rake) GoodParts adjustable brackets will be needed too. As a suggestion it will be a good time to convert to the TR6 lower front frame brackets with 2 studs instead of the 4A single stud pieces. Use the backup plates too for extra protection.
As for the upper A-Arms I have a source for modified / adjustable units on an exchange basis but they're not inexpensive ($350 to $400 bucks). Do some research and you may find alternate methods. BUT it must be done in order to get correct alignment and avoid excessive negative camber.
K TR2/3/3A What are the running symptoms........ Triumph 21
T General Tech Running hot Triumph 8
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
shadowfever Running well, then no fire Spridgets 7
C Rough-Running 3000 Austin Healey 29
S MGB Running poorly MG 7
tr6web TR6 TR6 rough running - what can it be? Triumph 17
Hamish Racing TR2/3/3A Winter engine running in - icy Triumph 7
R running car on jack stands Spridgets 16
BierRunner TR6 TR6 Running Rough Triumph 5
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
sparkydave Trouble running hot Spridgets 10
T TR2/3/3A rough running after 20 min shutdown Triumph 9
S TR2/3/3A Running rich SUs. Triumph 25
Y Wanted Looking for running 3.5L MK V engine Jaguar Classifieds 0
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
Gliderman8 Starter keeps running TVR 20
Rut MGB Running out of gas symptoms MG 21
K TR2/3/3A Anyone running NGK spark plugs? Triumph 26
T TR2/3/3A Anyone running tubeless radials on TR3 steel radials? Triumph 2
N Running Cold Austin Healey 12
bugedd Car running poorly Spridgets 7
Bob_Spidell Running hot/Overheating Austin Healey 44
Martinld123 SU carbs lose fuel prime when not running Austin Healey 3
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
N Stuck Needle Valve - Rough Running Austin Healey 15
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
BN6 Breaking In Running In a newly built Healey Engine Austin Healey 15
R TR2/3/3A TR 3A running hot at high rpm Triumph 12
M Proper running temp for 1275 Spridgets 28
HighAltitudeTR3 TR2/3/3A Running a little hot... Triumph 14
D Lilly running #3 / since last we talked.... Austin Healey 7
D Lilly second time running... or trying Austin Healey 8
D Lilly first time running in 15 years.... Austin Healey 19
sd80mac7204 TR6 Interesting TR6 running issue Triumph 19
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon TR5/TR250 Stumped TR250 Running Rough Triumph 8
F TR2/3/3A SUs Running Rich Triumph 25
S TR2/3/3A Struggling to stay running during warmup? Triumph 0
vette Constant Engine Running RPM. Austin Healey 20
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
C T-Series MGTC Running Boards MG 1
gbtr6 TR6 TR6 no start after running amazingly well til now. Triumph 16
K TR4/4A Running the motor witout the gearbox installed? Triumph 3
D Rough running BT7 3 carb HELP Austin Healey 13
M TR5/TR250 problem getting engine running Triumph 15
D Nice to hear the old girl running again. Austin Healey 2
R MGB-GT Just purchased Tuned for sea level, but I live at 7500', running rich MG 7
cpbol Sharing story - Solving issue of starving for fuel after running for 10 minutes Austin Healey 67
