TR4/4A Correct front radiator tray for TR4a sway bar?
tdskip
Pretty sure this was taken from a 1971 TR6, which I think shoudl work right?
PeterK
That's what I have on my 4A. Bolts right on.
I had to drill new holes for an Addco bar but I think the TR6 stock setup will fit the existing holes.
HerronScott
Yep, stock TR6 sway bar should work fine.
Scott
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
G Correct location of front turn signal on bj8 3000 Austin Healey 3
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
D BJ8 Front Seats Foam on Back Pan Correct Fitting Austin Healey 4
hymodyne GT6 correct front shock for 72 GT6 MK III Triumph 2
T Correct/best order for front suspension rebuild Spridgets 8
G Choosing the correct front coil spring Spridgets 54
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
