TR2/3/3A Routing of TR3 Temperature Gauge
GerryL
Does the temperature gauge tube follow along the fuel line or the heater pipe. In the book Original Triumph TR2/3/3 by Piggott, it appears in pictures both ways.
Which way did the factory do the install?
Geo Hahn
It follows (and is strapped to) the fuel line.
Here's a (less-than-perfect) example:
K TR2/3/3A TR4A 16P Girling Calipers Adapted to TR3. Hose/tubing routing? Triumph 15
M TR2/3/3A TR3 clutch hydraulic line routing Triumph 2
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
O TR2/3/3A TR3 Speedo Cable Routing Triumph 1
O TR2/3/3A TR3 Speedo Cable Routing Triumph 3
M TR2/3/3A TR3 Fuel line routing Triumph 6
Tinkerman TR2/3/3A Speedo Cable Routing TR3 Triumph 12
T TR2/3/3A TR3 front brake line routing Triumph 3
JohnnyMead TR2/3/3A TR3 - Routing the Temp Guage Tube? Triumph 5
T TR2/3/3A TR3 w/overdrive speedo cable routing??? Triumph 2
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D BT7 Air Vent Control Cable Routing Austin Healey 0
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
Healey Nut Rear Wiring Routing Austin Healey 2
Healey Nut Wiring Harness Routing Austin Healey 5
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
S Routing of Hand Brake Cable Austin Healey 6
R TR2/3/3A Speedometer Routing Triumph 15
M TR4/4A Speedometer Cable Routing Triumph 7
dklawson General TR Fuel Line Routing Triumph 4
F Heater pipe and air duct routing BT7 Austin Healey 3
S TR2/3/3A Routing the OD speedo cable Triumph 9
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
TRMark TR4/4A Choke Cable Routing Triumph 3
S TR4/4A What is the routing for the speedo cable Triumph 2
G TR4/4A Windshield Washer Tubing Routing Triumph 1
D TR2/3/3A Exhaust system routing and middle clamp Triumph 8
Gerald_Gordon TR4/4A Routing of wiring harness to the rear of a 1961 TR4 Triumph 8
CJD TR2/3/3A Overdrive Wire Routing Triumph 15
R Help with BJ7 front brake line routing Austin Healey 6
Csarneson Battery Cable routing pics on a BN4? Austin Healey 7
K TR2/3/3A Temp gauge capillary tube routing? Triumph 11
C routing of speedometer cable on BN6? Austin Healey 11
D TR2/3/3A Demisterr vent routing Triumph 6
Rut Brake line routing Spridgets 21
gbtr6 TR6 Need pictures of heater hose routing Triumph 0
M_Pied_Lourd TR2/3/3A Another Speedo Cable Routing Question.... Triumph 5
bugedd Fuel Leak and Proper Routing Spridgets 9
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
RAC68 Routing Oil Cooler Lines Austin Healey 16
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
B TR6 Reverse light wiring harness routing Triumph 4
tinman58 TR5/TR250 oil line routing Triumph 3
C BJ8 spedo cable routing Austin Healey 2
M Right Hand Drive cable routing Spridgets 11
AHS TR2/3/3A Disc brake line routing Triumph 0
