I am at the stage of installing the dash into my RHD Bugeye conversion. I am looking for a picture of the fire wall (or comment on the pics below) from the engine bay that shows the correct cable routing for the tachometer cable, speedo cable and heater control cable.
I believe that the temp sensor cable and the oil pressure line go through the same grommet and hole, but if that is not the case please correct me. I am pretty sure I have the brown battery wire and starter cable at least correct !
Please note that the wiring harness ... in fact the complete running gear ... is transplanted from a Mk2, hence the position of the Voltage Regulator and fuse box, as the wiring was not long enough to have them in the correct Bugeye position on the guard.
At present, the speedo cable is routed on the far left near the main harness as there was a hole here and the speedo is on that side of the dash. The tacho cable is pretty much a straight shot and is just to the right of the VR. To the right of that are the temp cable and oil line, with heater cable on the far right. Is that correct ? Any comments appreciated.
