General TR Fuel Line Routing
dklawson
I think that every Triumph I have seen runs a fuel line around the front of the engine up at the level of the T-stat housing then drops down to the carbs. Why not run the line lower where it wraps around the front of the block? I am assuming that with the old TRs having the big belts there is the possibility of the belt or a pulley hitting the fuel line but with the 1/2" belts there should be plenty of room shouldn't there?
Why is this of concern to me? The fuel line is obviously full when the engine is running. When the engine stops the fuel in the line isn't going to stay there, it's going to drip down into the float bowls. In the case of our GT6, I have an inline filter just before the carbs. The fuel from the line and the filter is draining down and overfilling the float bowls when the engine stops. That fuel is dripping onto the frame. It's also likely to be the reason I found fuel pooled in the intake manifold when I removed the carbs this past weekend.
Have you or anyone you know modified the fuel line routing so it is always going "up" instead of down?
trrdster2000
Doug, I have a cut off about where the old pump was located on the new Spit6. Had the diaphragm go bad on the TR6 and the Roadster, my cars do tend to set for long periods of time. The TR6 has one where you have a filter and the Roadster before the pump.
The later Spitfires ran down the firewall and I thought about that.
You might be interested in the idea I have about a brake flex hose to the clutch slave instead of the curly pipe. Uses on of the rear brake solid lines off the clutch master and a bracket off the fire wall for the flex hose. Still figuring on the right angle needed at the slave.
I know nuts!
TR3driver
Great Pumpkin - R.I.P
No, but I have replaced leaky float valves.
CJD
Our car has brand new float valves from Joe Curto. I suppose I can take them out and clean them but they should be clean.
+1. Just because they are new does mean they don’t leak. They could have been damaged during shipping.
There are too many moving, spinning things lower to run the line lower. There is only about 1/2” gap between the crank and water pump pulleys, and then it must route up and through the belt to the alternator. It is not worth the safety risk trying to find a route lower. If you insist on lower, then the rear of the block may be a better choice.
But...fix you float valves and higher will not be an issue.
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
AHS TR2/3/3A Fuel line to tank routing? Triumph 2
D Fuel Line Routing Spridgets 9
JohnnyMead TR2/3/3A TR3A Routing Fuel Line: Fuel Pump to Carbs Triumph 15
M TR2/3/3A TR3 Fuel line routing Triumph 6
CinneaghTR TR4/4A TR4A Fuel and Brake Line Routing and Dual Exhaust Triumph 6
chicken Wiring harness and fuel line routing Austin Healey 15
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
D TR2/3/3A rearmost fuel line question Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
JPSmit Fuel line - gas tank question Restoration & Tools 5
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
C TR4/4A Fuel line question..... Triumph 3
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
M Fuel Line Assistance Needed Spridgets 5
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
M BN1 carburetor fuel line Austin Healey 9
V TR2/3/3A TR-3B Fuel Line Question Triumph 7
E TR4/4A TR$ Fuel line from tank Triumph 13
H TR5/TR250 Fuel line route Triumph 3
mrv8q TR2/3/3A TR3 Fuel line rubbing Triumph 8
T TR2/3/3A Fuel line heat shield Triumph 39
M_Pied_Lourd TR4/4A TR4 fuel line run. Triumph 5
