TR2/3/3A rearmost fuel line question
deuce
Hello folks.. I have a later tr3a.. 78254. I'm replacing the gas tank with my build. The outlet is on the left.. drain on the right. My question.. Is the hard line which attaches to the tank secured to the underbody. I know another fuel line version goes crossbody and is clipped to the tub, but that is a much longer run to just let float. The one picture is what I had..almost 5 years ago
As an aside..anybody know where that little bracket goes. I guess that's two questions.. Thanks
CJD
The bracket goes under the driver's side dash, from the left dash brace to the steering column ubolt bracket.
I believe there is one clip for the fuel line, even for the A's. It would be apparent from a small hole that takes the clip along the left side of the tub, inboard of the frame. I'll look for pics of both these items when I get back to my main computer...
DavidApp
This is where I ran my fuel line. There was a clip on the tub on the drivers side.
I can't find the photos of the line along the frame.
David
deuce
Thanks John.. I have replaced all horizontal sheet metal from the firewall to the tail lights, so, no telltail hole. If you can find a picture of that little bracket in place it would be great!
I can't find the photos of the line along the frame.View attachment 69998View attachment 69999View attachment 70000
David
Thanks for the reply David. I can see from the pictures the outlet from your tank is on the right.. Mine is on the left so a much shorter run. Though I can't think of a reason not to clip the line to the tub.. keep it from slapping around. Isn't that copper/nickel line great.
CJD
It's dark, but you can make it out just to the left of the steering column. I was wrong, it goes forward directly to the bottom of the left side dash.
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
M Fuel Filler Caps Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
P XJ12 Fuel pump relay 85 Jaguar 4
