TR2/3/3A TR-3B Fuel Line Question
Vaark01
I can't find anyone selling the short fuel line with fastener that goes from the fuel tank line into the fuel pump. Gas is on the bottom of the line leading to the fuel pump and I can't tighten it to stop the seeping..
I talked with Moss and that line is the one part they don't sell.
Does anyone know where I can find one, along with what is needed to attach and tighten it on the fuel pump?
Thanks.
Paul
TR3driver
Great Pumpkin - R.I.P
I believe that on the later cars (without the shutoff valve), it's just a length of plain fuel line hose between the hard line to the tank and the hard line to the pump. 5/16" od IIRC, available at FLAPS or P/N 115784 @ TRF. Originally no clamps, but I suggest adding them (I believe even TRA accepts them as a non-penalty "safety" item).
The hard line to the pump is ordinary 5/16" od fuel (or brake) line, terne coated steel. Should be readily available at FLAPS. About 8" or so IIRC, with a gradual bend of about 30 degrees. TRF has the nut listed 60142, but I managed to find one at FLAPS.
The tricky part is the sleeve. The original sleeves had a different profile than modern sleeves do, and the ones I've bought from both TRF & Moss in the past were not right. Modern sleeves are tapered at both ends, while the original was flat on the end next to the nut and only tapered on the end that goes into the pump. The extra taper slides up inside the nut and effectively makes the sleeve so short that it will not seal properly before the nut bottoms into the threads in the pump. Overtightening the nut (in an attempt to stop the leak) can actually break the pump casting! That's been some years ago, so it's possible they have had sleeves made in the correct pattern, but I doubt it. Custom made parts would cost a lot more than $.50.
Several approaches you can try to deal with that. On my (previous) TR3A, I carefully filed the last thread off of the nut, so it could go deeper into the pump and compress a modern sleeve (readily available at Home Depot, etc). Another approach is to wrap teflon tape, or valve packing, around the line between the nut & sleeve. Perhaps the most elegant solution is written up here https://drive.google.com/open?id=0B2H2NJt34OffODA0ZmI4YTItNDhiZC00YmMzLTllOTUtZWVjN2U5MTUzZjA3
Geo Hahn
It won't look correct -- but I drove for years with a pump that had a brass barbed fitting threaded into it there. Probably had a taper thread. The car came to me like that so I cannot say if it was a common hardware store item (though I suspect it was).
TR3driver
My current TR3 had the same thing when I got it. The threads don't actually match, but the NPT threads on the brass fitting apparently jammed into the pump threads well enough to not leak.
Kleykamp
Interesting, Mine has a flare on the fuel pump end of the 5/16 steel pipe and has no brass sleeve. The threaded fitting tightens down on the flare and I have no problems. Just recently changed the fuel line rubber hose because of cracks in the old one. My car is a '61.
D TR2/3/3A rearmost fuel line question Triumph 5
JPSmit Fuel line - gas tank question Restoration & Tools 5
C TR4/4A Fuel line question..... Triumph 3
K TR2/3/3A Odd question re: rear axle hitting fuel line? Triumph 4
J Fuel line fitting question Spridgets 6
M Fuel Line to Tank Connection Question [pics] Triumph 2
H Fuel Line Question Triumph 3
JohnnyMead TR2/3/3A TR3A Fuel Tank-Fuel Line Question Triumph 8
J Fuel line question Triumph 16
V TR2/3/3A TR-3 Fuel Line Question Triumph 31
V TR2/3/3A TR-3B fuel line question Triumph 3
jjbunn Fuel Line Question Triumph 7
SCguy TR4/4A TR4 Fuel line to fuel pump question Triumph 8
jlaird Question, fuel line Spridgets 3
SCguy TR4/4A Fuel Tank, Fuel line question, TR4 Triumph 7
J TR4/4A TR4 Fuel Line to Carbs question Triumph 2
A TR2/3/3A Those round fuel line clips Triumph 2
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
Walter74 Fuel Line Routing Austin Healey 7
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
G TR6 Clogged fuel line Triumph 6
petnatcar Fuel Line Upgrade Austin Healey 8
B TR4/4A Rear Fuel Line Routing IRS Triumph 5
MGTF1250Dave T-Series MG TF fuel line from tank to pump MG 3
M TR2/3/3A Fuel Line Fitting at the Tank. Triumph 5
steveg TR6 Source for fuel line P-clip Triumph 17
T TR2/3/3A Can someone confirm size and thread count on fuel line tube nuts [brass fittings]? Triumph 16
Bayless What size fuel line for '67 Sprite? Spridgets 2
dklawson General TR Fuel Line Routing Triumph 4
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
D 62 tri-carb fuel line connection Austin Healey 10
D TR2/3/3A Fuel line run from pump to carbs Triumph 5
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
D TR2/3/3A tr3 fuel line Triumph 9
S General Tech fuel line vents in general Triumph 4
R BJ7 end couplings for fuel line Austin Healey 7
G Wanted TR4 Water Pump Housing and Fuel Line Triumph Classifieds 3
G TR4/4A Using existing fuel line Triumph 5
G Wanted TR4/4A[?] Stay Rods and Fuel Line Triumph Classifieds 1
C TR2/3/3A Flexible fuel line Triumph 2
V TR2/3/3A Fuel Line into Fuel Pump Triumph 5
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
M Fuel Line Assistance Needed Spridgets 5
J TR4/4A Fuel line Triumph 2
petnatcar FUEL LINE CONVERSION for BT7 Austin Healey 1
DornTRoriginal TR2/3/3A Gas Line/Fuel Pipe Installation Questions Triumph 2
