TR2/3/3A Flexible fuel line
carpecursusII
On the TR3 that was fitted with banjo fittings and H6 carbs, they were coupled with a flexible "smiths Petro-flex" braided steel line. This line was fastened to the hard line coming from the fuel pump with a compression fitting and a nut. I have the original petro-flex line and fitting, what I need is the nut or someone who can tell me what thread the nut is.
TR3driver
Great Pumpkin - R.I.P
Best I can tell, the threads are 1/2-20. I found the original hard line from TS13571L with the nut still on it, and tried the nut on the fuel tap (where it fit snugly); then measured the male threads on the tap.
Sorry, I don't want to part with it, but this appears to be a usable substitute:
https://www.mcmaster.com/?m=true#52215k523/=15z5e53
Note that the threads are different than the common brass fittings.
Roger Flexible fuel line Restoration & Tools 1
R Flexible fuel lines MG 1
S TR2/3/3A Flexible banjo fuel lines on early tr3s Triumph 0
fpstude TR4/4A Replacing Rear Flexible Brake Hoses on TR4A w/ IRS Triumph 11
G TR2/3/3A Hydraulic supply lines from reservoir..replace with flexible Triumph 19
F Advice replacing flexible brake pipes on BT7 Austin Healey 3
F Replacing brake master cylinder, fluid reservoir and flexible brake pipes - order? Austin Healey 4
R Can't remove rear flexible brake hose Spridgets 5
maxwedge5281 substitute rear brake flexible hose.... Austin Healey 5
D flexible brake lines Austin Healey 4
T Steering flexible coupling - how easy to replace? Triumph 24
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
