KVH
TR4:
The brass fitting I have at the pump outlet (to the carbs) doesn't have a long enough reach to compress the ferrule inside the fuel pump. I'm referring to the outlet part of the pump with 1/4" line. Have folks talked about that around here before? The fitting is 1/2-20, but every single fitting I find to replace mine is the same length. Is there such a thing as a longer ferrule? What's the fix?
