TR2/3/3A Speedometer cable routing and dash switch layout.
John_Progess
I have an overdrive on my 60 TR3 which has the 96" long speedometer cable. Is there a preferred routing to the dash? Also I have checked pictures of car dash switch layout and mine seems different (I also have an aluminum windshield frame!). My dash has the panel light restate in the middle of the 3 switches based on the size of the hole in the dash. The panels I have seen have the panel light switch on the top of the 3 switches. Did they make a change at some point? Thanks for your help and have a good day!
John
TR3driver
Great Pumpkin - R.I.P
The speedo cable crosses over the engine on the ledge in front of the battery, with a clip and screw to hold it there. Then it makes a gradual bend down the firewall on the RH side and follows the inner frame rail (I think there should be a spring clip to the frame, but not certain where offhand) until it loops around and comes up through the floor behind the handbrake lever. Then through the boot, back through the hole in the transmission tunnel and onto the OD. I was seeing some damage where it went through the sheet metal, so I slit a length of old fuel line and put that over the cable as protection.
Here's a shot of TS38781LO with what I believe is the original cable routing and clip (although the screw is probably wrong).
The rheostat does belong in the center of the dash. Early cars had a simple switch located at the top, but there isn't really room there for the rheostat, so the rheostat was moved to the center and the wiper switch put at the top. You can see the later arrangement documented in Practical Hints 6th edition
https://drive.google.com/file/d/0B2...M2U2LWJhYWUtMjEyZDgxMzUyNzUw/view?usp=sharing
According to Bill Piggott, the rheostat appeared on some cars starting at approximately TS43000, but didn't become standard on all cars until TS60000. But the rheostat takes a larger hole than the simple switch, so the panel itself is different depending on whether the rheostat or switch was used originally.
fpstude
Randall, thanks for the link to the TR3 Instruction Book. It will be a great help as I work on the TR3 at the California Auto Museum. The forum helped me find a flex oil hose earlier today.
M TR4/4A Speedometer Cable Routing Triumph 7
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
C routing of speedometer cable on BN6? Austin Healey 11
J TR4/4A TR4 Speedometer cable routing Triumph 0
TimK Speedometer Cable Routing - BN7 Austin Healey 2
HEALEYJAG 100 speedometer cable routing Austin Healey 5
6 Speedometer Cable Routing Austin Healey 2
B Speedometer Cable Routing Question Austin Healey 3
G Routing the speedometer cable Austin Healey 4
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
P TR6 Jumpy Speedometer cable Triumph 4
S BJ8 Speedometer Cable Austin Healey 6
S Speedometer Cable Spridgets 5
P TR6 speedometer cable Triumph 21
R TR2/3/3A TR 3A Speedometer Cable Route Triumph 12
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
C TR2/3/3A Speedometer cable fastener locations Triumph 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
K TR2/3/3A Speedometer cable fittings? Triumph 4
B TR6 Brand New Speedometer Cable breaks Triumph 5
Patrick67BJ8 Speedometer Cable-5-speed Trans Austin Healey 6
R Smitty Speedometer Cable Fix Austin Healey 1
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
G TR4/4A tr4a speedometer cable Triumph 9
angelfj1 Speedometer [cable failure] and repair Triumph 5
longbridgehealey Speedometer cable not spinning Austin Healey 15
T Quesiton on A-type OD speedometer cable fitting Triumph 12
D speedometer cable Austin Healey 17
T TR4/4A TR4 Speedometer Cable Triumph 3
bcbug Another speedometer cable replacement question Spridgets 4
bighealeysource T-Series Stuck speedometer cable on TC MG 3
J Speedometer cable issues? Austin Healey 7
V TR2/3/3A TR-3B Speedometer Cable Triumph 6
gubba speedometer cable right angle adaptor Triumph 4
JPSmit speedometer cable question Spridgets 8
Sarastro Source of a good speedometer cable? Spridgets 5
S Speedometer Cable Installation Problem Austin Healey 5
Magyar Speedometer and cable Spridgets 5
S Lubricating Speedometer Cable Austin Healey 13
T Speedometer cable Triumph 0
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
walshja speedometer cable Spridgets 9
S TR2/3/3A Speedometer cable tr3 Triumph 3
C speedometer cable issue MG 2
T Speedometer and cable Triumph 2
W speedometer cable and housing MG 7
I TR6 TR6 speedometer cable Triumph 3
