Speedometer cable not spinning
Hi all, If my speedo cable suddenly stopped spinning, and I'm guessing that I have to get to the angle drive. Can this be done from underneath, or do I have to pull up the carpet and tunnel?
Thanks!
Larry
John Turney
Thanks!
Larry
On my BN4, I have to pull the carpet and tunnel.
Donny_L
I just changed mine out a few weeks ago. I might have been able to do it from under the car but it would have been a real bugger.I had to work on the overdrive too,so I took took out the tunnel and it was easy from there. the toughest part was getting the tunnel off. Doing it this way made it easy to clean it all out really well also.
Donny_L
Bob would definatly know better than me. I'm completley new to all of this and that was the first one I ever had to do. His expierience has probably done this a few hundred times. If he says it can be done, I say do it his way. :smile:
bob hughes
For my money, I would go in from the top, much easier to see what you are doing and you can check on the state of the cable in this area and the clutch slave cylinder, line and the rubber gromet into the bell housing along with the overdrive cable, grease up the hardy spicer at the end of the drive shaft at the same time.
My trans cover is not fixed down and acces is easy.
:cheers:
Bob
Johnny
Hi Larry, hope I'm not too late to offer advice. I feel it's easier to go in from the top also. If it's stopped spinning altogether the culprit may be the angle drive. Usually what happens is the round bushing on the end facing you comes off and the gears fall out. If you're lucky they just fall or get wedged on something and can be recovered. You can put them together easily then secure the round bushing by staking it in place. You'll see what I mean when you have it off.
longbridgehealey
Thanks everybody. I'm thinking in from the top (although I DON'T WANT TO!!). :wall: Can't get to it until next week, so I'll keep you posted on the outcome.
Larry
Larry
Do it from the top. Plenty of access...
Legal Bill
By the way, Beware of aftermarket speedo cables that are too long. I had a talk with the folks at Nissonger and they tell me that some of the aftermarket speedo cables have inner cables that are too long for the application and cause damage to the speedometer. With the cable installed at the transmission end, the inner cable should protrude exactly 7/16ths of an inch from the face of the metal collar that sits flush against the threaded fitting on the back of the speedometer. This is the case for my BJ8. Not sure if it is the same for other models with different speedos.
If you're going to go to the trouble to remove the transmission cover I recommend you install a clutch bleeder extension while you're in there (I have a BJ8 and removing the cover is more trouble than with a roadster). Bleeding the clutch slave is a PITA, but with the extender it's a piece of cake (I had a sloppy pedal on a long road trip and bled the cylinder in a parking lot waiting for a steakhouse to open; took about 5min.).
Contact Doug Reid at mrfinespanner@earthlink.net
I had the trany cover off and out in less than 20 minutes when I dropped the tubing in the gear box filler hole. And that is with a BJ8 radio and consul to remove. You don't have to pull it all the way up and out to get to the OD. You probably could get away with just removing the seat bottoms and the 8 screws that hold the cover to the floor and lift 4 or 5 inches. Putting mine back took a lot longer 'cause I cleaned a lot of stuff you don't get to see often.
I'm assuming you don't have a BJ8 with the consul by your Longbridge title.
longbridgehealey
Thanks, Bob - Doug is a good friend of mine. He put his (prototype) bleeder extension on both of my Sprites, and you're right, this is a great time to install it on the 100-6.
Larry
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
P TR6 Jumpy Speedometer cable Triumph 4
M TR4/4A Speedometer Cable Routing Triumph 7
B Speedometer Cable Routing Austin Healey 9
2 TR2/3/3A Non OD speedometer cable routing diagram/pictures. Triumph 7
S BJ8 Speedometer Cable Austin Healey 6
S Speedometer Cable Spridgets 5
P TR6 speedometer cable Triumph 21
R TR2/3/3A TR 3A Speedometer Cable Route Triumph 12
C routing of speedometer cable on BN6? Austin Healey 11
KVH TR4/4A Long Speedometer Cable for OD Transmission Triumph 10
J TR2/3/3A Speedometer cable routing and dash switch layout. Triumph 2
Scotsman TR2/3/3A HVDA transmission conversion. 90* speedometer cable adapter may be required on TR3's Triumph 4
C TR2/3/3A Speedometer cable fastener locations Triumph 14
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
K TR2/3/3A Speedometer cable fittings? Triumph 4
B TR6 Brand New Speedometer Cable breaks Triumph 5
Patrick67BJ8 Speedometer Cable-5-speed Trans Austin Healey 6
R Smitty Speedometer Cable Fix Austin Healey 1
O TR2/3/3A TR3 Speedometer Cable length? Triumph 5
G TR4/4A tr4a speedometer cable Triumph 9
angelfj1 Speedometer [cable failure] and repair Triumph 5
J TR4/4A TR4 Speedometer cable routing Triumph 0
T Quesiton on A-type OD speedometer cable fitting Triumph 12
D speedometer cable Austin Healey 17
T TR4/4A TR4 Speedometer Cable Triumph 3
bcbug Another speedometer cable replacement question Spridgets 4
bighealeysource T-Series Stuck speedometer cable on TC MG 3
J Speedometer cable issues? Austin Healey 7
V TR2/3/3A TR-3B Speedometer Cable Triumph 6
gubba speedometer cable right angle adaptor Triumph 4
TimK Speedometer Cable Routing - BN7 Austin Healey 2
JPSmit speedometer cable question Spridgets 8
Sarastro Source of a good speedometer cable? Spridgets 5
S Speedometer Cable Installation Problem Austin Healey 5
Magyar Speedometer and cable Spridgets 5
S Lubricating Speedometer Cable Austin Healey 13
T Speedometer cable Triumph 0
2wrench TR6 '74 TR6 Route of speedometer cable from overdrive. Triumph 7
walshja speedometer cable Spridgets 9
S TR2/3/3A Speedometer cable tr3 Triumph 3
C speedometer cable issue MG 2
T Speedometer and cable Triumph 2
W speedometer cable and housing MG 7
HEALEYJAG 100 speedometer cable routing Austin Healey 5
I TR6 TR6 speedometer cable Triumph 3
Rob_P Speedometer Cable MG 7
AUSMHLY Speedometer cable length Austin Healey 4
T Broken Speedometer Cable Triumph 5
