TR4/4A Windshield Washer Tubing Routing
ghawk16
OK...I guess I didn't take enough pictures when taking apart my car. And since I tore it apart over 4 years ago...I just can't remember. I'm trying to remember the routing for the tubing coming from the washer bottle to the pump, then most importantly from the pump up to the upper dash. I know the tube goes in the firewall, but does it just route itself randomly behind the dash to the pump or does it get tucked in the wiring harness clips as well? Then the big question, once it goes from the pump how does it go back up to the "T" by the wiper boxes. I know by the passenger access hole (where the black plate with four screws goes) there is a small hole for a grommet, but I thought that was for the windscreen flap rod for cool air. Or is that for the tubing? If it isn't for the tubing, how does the tubing get back there? Confused? Sorry guys for all the questions. And yes, just using normal Lowes bought clear plastic tubing unless someone can point a source for the proper off white tubing. Thanks!
sail
Mine is loosely threaded. From the firewall it comes straight back and turns the corner by the dash behind drain tube. Then draped over the steering column and a bit of a loop to the pump. From the pump loose up the passenger side of the heater to the dash. Thats where I lost it.
R Windshield Washer Pump Repair Austin Healey 9
Got_All_4 TR2/3/3A Where to place the switch for the windshield washer & bottle Triumph 8
I TR6 Windshield washer jets...placement and installation Triumph 1
Gordon_Dedrick Windshield washer hose Triumph 4
dcoplan Looking 4 windshield washer container replacement Spridgets 10
F BT7 Windshield Washer Pump Austin Healey 1
M Manual windshield washer? Spridgets 19
The_architect Windshield washer container for Bugeye Spridgets 14
T TR2/3/3A TR3 Windshield washer pump Triumph 14
Tinkerman Windshield Washer Pump Question Triumph 8
M Windshield washer bottle strap dried up. Triumph 7
J Windshield Washer Reservoir - MKII Austin Healey 6
CraigLandrum TR2/3/3A TR3A Windshield washer info needed Triumph 9
N 1974 Windshield washer tank mounting Triumph 8
J Windshield washer 1978 midget-bag on fender system Spridgets 0
rulle7 Windshield washer jets Spridgets 0
regularman Question on windshield washer pump Spridgets 3
rulle7 Windshield-washer incontinence Spridgets 6
S T-Series Windshield Washer Switch Spring MG 0
Dan_Pasta TR2/3/3A TR3A windshield washer??? Triumph 14
Mark_Gibson Windshield Washer on a 1955 TR-2 Triumph 2
G MGB windshield washer system 1978 MGB MG 9
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
