TR4/4A tr4 temperature gauge/sensor reading
derickson
Member
After my recent rebuild on my '63 tr4, the temperature sensor now reads 100 deg when warmed up and 40 deg when cold. The temperature sensor resistor reads 880 ohms when warm and 88 ohms when cold. I'm trying to figure out if my sensor is bad, or if the gauge is bad, or if the engine really is running that hot. It seems to run normally, and doesn't overheat, so I'm suspecting the gauge or sensor. Any ideas?
mrv8q
Re: TR4 temperature gauge/sensor reading
Check it with a digital thermometer at the sender...when my car reads 185º, I know it's 177º at the sender.
piman
Hello Derickson,
the sender should decrease in resistance as it heats up so it sounds as though yours is U\S. The standard quick check of both the temperature and fuel gauge is to short the sensor terminal or cable to earth and the instrument should be on full scale.
Alec
Geo Hahn
Are those degrees Celsius or Fahrenheit? I do not recall what the change point was between early & late TR4s.
KVH
That's a good question, Geo. I was looking at the converter last week. 40 C would be well over 100 F, and 100 C would be over 200 F. I think the converter uses a fraction of about 1.8, and adds 32 degrees. I get confused whenever I look at the differences.
Geo Hahn
I think Triumph was confused too.
The middle of the 'old' gauge is 185F.
The middle of the 'new' gauge is 70C.
The conversion formula is C = (F-32)*(5/9)
So 185F = 85C
But if you do the operations in the wrong order => C = F*(5/9)-32 then you get 185F = 70C
What I suspect: Some shiny-pants junior engineer got the calculation wrong and ordered gauges from Smiths that centered on 70C rather than 85C.
Triumph (and other mfgs) finally resolved the problem by dropping the numbers altogether.
Adrio
I have put the sender from my TR4A through a lab test and these are the result. Temperatures in degrees F. resistance in OHMS.
100 deg F = 502 ohm
120 deg F= 320ohm
140 deg F= 206ohm
160 deg F= 139ohm
180 deg F= 99ohm
200 deg F= 72ohm
208 deg F = 62 ohm (at my altitude and the pressure of the day this was boiling temperature)
You need less resistance to have more current in order to heat up the metal strip that moves the needle in the temperature gauge when the engine temp goes up.
I have values for every 10 degrees but did not want to type it in.
It would appear that your set up is off as the resistance is varying inversly to what is expected but your gauge is going in the correct direction. Did you type those values in correctly??
derickson
Member
I did get my measurements backward. It should be 88 ohms with engine hot, 880 ohm cold. My gauge reads in celsius (I assume, since it's not marked); and is marked at 30, 70, and 100. From the measurements that Adrio took, it looks like my sensor is operating correctly, but the gauge is displaying a higher than expected reading (from his, 88 ohms on my sensor should be about 190 F, which is consistent with operating temp for my 187F thermostat).
I'll also try shorting the sensor lead to ground, but since it currently reads full scale when the engine is warmed up, it can't go any farther.
How do you measure the temp with a digital thermometer? Just contact measurement at thermostat housing or radiator upper hose?
martx-5
Since the Ohm readings on the temperature sender appear to be OK, perhaps the gauge voltage stabilizer is not putting out the correct voltage.
Adrio
that is probably your problem. If you have no voltage stabilizer or a defective one you will get a high reading. The reason I did the lab test on my sender was in order to figure out what voltage I needed to make a solid state regulator for in order for my gauge to read correctly. I had no voltage stabilizer before that and I always had full scale on the gauge.
So that is where I would start to look if I were you. Take an analog volt meter and measure what the input voltage to your gauge is (the side of the gauge that does not go to your sender unit). It should be between 10 and 12 volts with the car running at any speed. If you are getting in the 16 volt range then it is your instrument voltage stabilizer that is the problem. An other way to check is to disconnect your generator and drive the car on battery alone (maybe do this after the engine is warmed up). This should tell you if your guage will read closer to the true temperature. If it does then for sure it is your instrument voltage stabilizer
derickson
Member
I'll check this, but I recently rebuilt the voltage stabilizer with modern solid-state electronics, and when I checked it a month ago, it was steady at 10V.
Is it possible to re-calibrate the temp gauge? I guess the other possibility would be to add a resistor in series so that when hot the total resistance would result in a correct reading, but that seems cheesy. It should work how it was designed.
Adrio
If you open the temp gauge you will see that it is little more then an electric heater wire wrapped around a metal strap. As the heater gets warmer (higher current) the metal expands more and that deflects the needle. From this there may be a bit of calibrations that is possible. I played with mine a touch and was able to get it to read correctly, but it was no where near as far off as your was.
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
Ericstammer TR4/4A TR4A body on TR4 frame Triumph 0
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
K For Sale TR2-TR4 Camshaft Sprockets...New...1/2 Price Triumph Classifieds 0
P Wanted WTB Restorable TR4 Triumph Classifieds 7
A TR4/4A TR4 Overdrive Solenoid Triumph 19
J For Sale 1965 TR4 + TR3 Parts - floors, gauges, misc. Triumph Classifieds 14
D TR4/4A Automatic transmission in a TR4 A Triumph 13
Twit TR4/4A First startup of TR4 Triumph 4
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
Lotuswins TR4/4A Is this normal? TR4 gap between door and cowl Triumph 10
R Tr4 restoration books Restoration & Tools 2
M TR6 EZ EPAS Steering Column Fitment to TR4-6. Triumph 0
Kurtis TR4/4A TR4 Wiper Arm Remval Triumph 2
