TR2/3/3A Temperature Gauges Again
karls59tr
Bronze
I bought a Smiths temperature gauge that is from a Cobra that has the face and lettering that looks very much like the original TR3 gauge. It seems to function OK in that the dial moves but the temperature reading is not accurate. Where can I send it to get re calibrated that wont cost me several hundred?:p
CJD
Do it yourself. It’s about a 30 minute project for free. Nisonger and West Coast will want gold dabloons
CJD
You can follow me along starting at post #100
https://www.britishcarforum.com/bcf/showthread.php?94885-Instrument-Faces/page3
In this thread I calibrated the temp gage in the kitchen. Later I overheated the car and the gage popped off the bellows, so I re-calibrated IN the car, as I didn’t feel like removing the entire capillary tube again.
Remove the chrome bezel ring by twisting it, so the locking tabs line up with the open slots on the housing. Then the bezel, glass, and seal pop off. You can slide the painted face out and see how simple the gage is. By alternating the temp bulb from boiling water and room temp you can bend the little wire on the bellows to engage the needle and eventually get the correct range from minimum to 212 degrees.
T General TR Request pictures of TR3B & TR4 electric temperature gauges Triumph 15
R Electronic Temperature and Oil Pressure gauges Austin Healey 3
C Engine Operating Temperature Austin Healey 21
PDIGIO_6x3 TR6 Temperature Compensators Triumph 3
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
BierRunner TR6 Temperature Gauge Triumph 8
A MGB Stuck water temperature sensor MG 26
S TR2/3/3A What temperature of electric fan switch do you use in your radiator? Triumph 3
R Coolant temperature gauge Spridgets 8
nevets Coolant Temperature Austin Healey 13
longbridgehealey Temperature sender Austin Healey 18
TRclassic3 TR2/3/3A Timing and temperature Triumph 13
B TR2/3/3A TR3 Temperature gauge Triumph 19
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
S Meaning of the ‘dots’ under the temperature scale? Austin Healey 3
GS67 1500 Operating Temperature Spridgets 2
J TR4/4A Water temperature and electric fan in a TR4 Triumph 5
N BT7 water temperature sensor removal Austin Healey 13
pkmh How hot can it [temperature gauge] get? Austin Healey 4
T Wanted WTB early TR 4 electric temperature gauge Triumph Classifieds 5
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
S BJ7 frozen temperature sensor to block Austin Healey 17
S TR2/3/3A Temperature Guage Triumph 3
Jer is it posible to fit an electric temperature gauge ? Spridgets 4
BN6_2197 Question on correct oil temperature Austin Healey 15
Bugeyze Temperature Austin Healey 14
BN6_2197 Question on Oil Temperature Gauge Austin Healey 1
6 Temperature/Pressure Gauge Spridgets 7
D TR2/3/3A Temperature gauge Triumph 13
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
K TR2/3/3A Replacement Temperature Gauge Triumph 5
M TR4/4A Temperature and Fuel Gauge Wiring...Help Wanted Please Triumph 6
Michael Oritt Temperature sender fitting at radiator on BN1 Austin Healey 3
R TR2/3/3A Normal vs Max acceptable coolant temperature? Triumph 14
S Air/Fuel Mixture affect on Coolant Temperature? Spridgets 2
Dave Richards Temperature Guage Austin Healey 11
J 1964 AH 3000 operating temperature Austin Healey 10
BN6_2197 BN6 Temperature Issue Austin Healey 12
G TR2/3/3A Routing of TR3 Temperature Gauge Triumph 2
BN6_2197 Oil Temperature Gauge for BN6 Austin Healey 6
andrea Problem with the throttle linkages due hing external temperature Austin Healey 34
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
GBT MGB-GT air temperature control valve MG 1
B Path of Oil Pressure/Temperature Lines Spridgets 2
K TR2/3/3A TR3 Temperature Gauge...cost to repair? Triumph 11
Tugboat TR2/3/3A Original T3A Temperature Gauge Triumph 13
Anthony_S temperature gauge....HELP Triumph 18
Nelson "High" temperature adhesive Spridgets 7
L Temperature sensor relocation in BE with A 1275 Spridgets 8
