Air/Fuel Mixture affect on Coolant Temperature?
SaxMan
With the driving season well underway, there's been a couple of things Baby Blue is doing differently this year compared to last year -- not bad, but different.
One thing I've noticed is the car is running warmer. It's still staying on the good side of the "N" on the temperature gauge, but now it is more likely to be hugging the "N" as opposed to last year, when the only time it approached or went over the "N" was when I was low on coolant. Under normal conditions, though, the car always ran cool. There were no changes to the cooling system, other than replacing the heater return line. Same thermostat. Same brand coolant.
I had heard, at least with aircraft engines, that an engine running lean will run hotter than one running rich. I started noticing the temperature gauge sticking much closer to the "N" range when I richened the carb mixture. I'm thinking if there is more gas to burn, that would equate to more heat = higher operating temperature? The other thought was when I yanked the dash (and pulled the probe) that I unclogged or freed up something which is making the temperature gauge read more accurately.
Last year, Baby Blue was eating a quart of oil every 300 miles like clockwork through the self-lubricating chassis system and oil getting past the rings. This year, the oil consumption has dropped in half. I think part of that was me fixing a rather nasty oil leak on the valve cover gasket, and maybe I did a better job of adjusting the valves this winter. Could oil consumption also be affected by mixture? More gas to burn during combustion means less oil that gets burned?
nomad
Timing can affect temp but I don't think that fuel would make a huge difference. Carb balance or anything that adversely affects performance can make a difference though. Usually the sweeter it run's the cooler it run's.
Kurt.
S
SaxMan
I did replace the vacuum line between the distributor and the carburetor, as the previous one was leaking at the carburetor end...I guess that would affect timing?
M Warm days and air/fuel mixture Triumph 11
hondo402000 TR% Air to Fuel Ratio Triumph 46
NutmegCT Air in the fuel line? Triumph 11
RAC68 Air/Fuel Ratio Meter Austin Healey 17
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
martx-5 Air Fuel Ratios & SU Carbs Triumph 10
Stewart Air fuel ratios MG 4
M Air Fuel Gauge Spridgets 6
Brosky Air/Fuel Ratio Meter and Damper Rebuild pages Triumph 0
PATR8 air/fuel and compression testers Triumph 2
Trick6 Air Fuel Ratio Sensor/Monitor Triumph 18
Atrus Air in fuel filter Spridgets 11
M How Important Is Fuel Cooler in Air Cond. 87 XJ6? Jaguar 6
M XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement Jaguar 0
M TR4/4A Difference between two Oval Air Filters Triumph 3
K TR2/3/3A Foam air filters for S U's Triumph 7
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
WHT DW ITG Air Filter Austin Healey 3
Carlbanan56 MGB Puling air MG 5
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
Writer2022 GT6 Overheating after fitting air filters Triumph 4
Celtic 77 MGB Tinny Zenith air regulator MG 0
Celtic 77 MGB Seized air pump issue MG 25
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
D BT7 Air Vent Control Cable Routing Austin Healey 0
DrEntropy MGB Air filter MG 16
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
F TR4/4A Replacement air filter for SU HS6 Triumph 6
A MGB MGB flap and air box MG 60
R For Sale TR6 AIR CLEANER BOX Triumph Classifieds 1
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
tahoe healey Cooper Air Filters Austin Healey 7
petnatcar Air Scoops Behind the Grille Austin Healey 0
D Wire Wheels and Air Leak Austin Healey 16
rr64 Wanted WTB: Weber 45 DCO 3 Carburetor Air Horns Other British Classifieds 2
PC air back there... Spotted 0
equiprx Air Compressor Moisture mitigation Restoration & Tools 17
S TR2/3/3A restore my original air filters Triumph 5
J Wanted ZS 175 CD-2 Air Valve Triumph Classifieds 0
D Wanted TR6 exhaust manifold w/air rail Triumph Classifieds 2
E MGB Oiling foam air filter MG 3
E MGB SU carb air cleaners MG 10
RAC68 Cold Air Bilge Blower update Austin Healey 13
P TR6 New front shocks & air in clutch Triumph 15
N Air filters Austin Healey 5
M Cooper's Air Filter on H1 Carbs Spridgets 5
TomMull Scroll Air Compressor Restoration & Tools 13
K For Sale TR4A Intake Manifold..Put one on your TR3...improves air intake....cheap like borsht. Triumph Classifieds 2
