Warm days and air/fuel mixture
M
Member 10617
Finally, the days are warming up here in western Virginia (not to be confused with West Virginia). I took the TR3 out yesterday for a 150-mile trip over and along the Blue Ridge Mountains. A wonderful ride through beautiful early spring territory.
But although I had carefully set the air-fuel mixture a month or so ago, the car dieseled whenever I shut it off (running too rich, I assumed). I did several road-side adjustments and finally eliminated the dieseling.
But I wonder, can warm weather affect the mixture that much, so that adjustment is necessary season to season?
Twosheds
As temperature and altitude increase, the mixture richens.
Enough to require an adjustment? I dunno.
M
Member 10617
Dr. John,
Well... it was certainly warmer than when I first adjusted the mixture, and I was up in the mountains. So perhaps that explains it. The dieseling wasn't too bad.
TR3driver
Great Pumpkin - R.I.P
With carbs, fuel mixture is always a compromise, rarely perfect for conditions. They basically mix by volume, so anything that affects the density of either air or fuel will change the mixture, including not just altitude and intake air temperature but seasonal changes in fuel composition. So touching up the mixture from time to time is a reasonable thing to do, IMO.
But I've had enough trouble with dieseling in the past that I've developed the habit of always killing the engine with the clutch. Just leave it in gear, right foot firmly on the brake, turn off the key and just as the engine should be almost stopped, let out the clutch.
M
Member 10617
Randall,
Now that's an idea. If the dieseling keeps up, I'll try your solution.
The pollen level is so high around here right now, that I'm almost tempted to say that perhaps it is contributing to making the mixture rich by cutting down on the air... ha, ha.
tr8todd
Double check your timing as well. If the dizzy isn't locked down tight, a little movement can also be a contributing factor.
TR3driver
High idle will do it too.
M
Member 10617
We set the timing about two weeks ago and locked down the distributor. Probably not the problem, but will check it out.
UPDATE: I checked the distributor and it is rock solid -- no movement at all. So I don't think there's any drift there.
Also, my idle has always been around 1100-1200 rpm. That's where it is now.
UPDATE: At one of my road-side adjustments, I ran the adjusting nut all the way up and down nine flats. That seemed to take care of the dieseling. Many of the manuals say to screw it down twelve flats before fine-tuning, and that is what I may have done before. Perhaps that was too rich. At any rate, at the end of the day yesterday, there was no more dieseling.
TR3driver
A word to the wise : the distributor clamp grabs a fairly weak part of the distributor body. Even though it's a fairly big bolt, you should tighten it only enough to keep the distributor from turning. Otherwise you can break the casting.
12 flats down is merely a starting point, it's not likely to be anywhere near correct except by sheer coincidence. (And the factory workshop manual suggests starting at 15 flats instead of 12.) IMO roadside adjustments are much better made by either doing the "lift the piston" test, or listening to the exhaust note at idle.
The weather has gotten a bit warm here, so I backed off a flat myself after lunch.
M
Member 10617
Randall,
Well, actually, I started nine flats down and then did the "lift the piston" test with the piston lifting pin. I don't think I had to do any more than two or three flats more to fine-tune the carbs.
A mechanic friend of mine tightened the distributor clamp, and it looks like he got it pretty tight, but I can't see that anything has been broken. Which casting are you referring to: ---the distributor clamp itself?
TR3driver
Don't worry, Ed, if it seems tight then it's not broken.
The clamp is not a casting, it's bent from heavy sheet steel and not likely to break. But the distributor body is a "pot metal" (zinc alloy) casting, and it can break.
M
Member 10617
Randall,
I suspected that was what you were warning me of. I looked carefully at the distributor body -- what I could see of it -- and all seems well. At any rate, it is tight and doesn't turn.
Darwin Warm days and sunshine in Montana....... Triumph 2
R TR6 J-Type overdrive will not disengage when warm Triumph 8
drooartz MGB OD question - need to warm up? MG 8
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
R Screen for warm air side Austin Healey 26
C TR6 Zenith Strombers won't start when warm. Triumph 2
I TR6 Left wheel gets warm when I drive Triumph 8
A 1985 280i - stalls when warm TVR 6
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
T TR4/4A Overdrive fade when engine is running warm Triumph 5
T Dust cap feels surprisingly warm after short drive Triumph 7
Jim_Gruber Running too warm at sustained high speeds Spridgets 5
T TR2/3/3A TR3 Warm Up Issues Triumph 10
RickB Finally warm and sunny, top down and I'm out!! Spridgets 4
BN6_2197 Overdrive not engaging when engine warm Austin Healey 15
T H-E-L-P OD Drops out when warm MG 1
bigjones Needs choke when warm Triumph 8
S MGB My MGB is warm blooded..... MG 7
J 145 - 130 - 155 - 160 warm compression test Triumph 10
scoutll Time for a warm fire and a good book,.... Spridgets 8
B Spitfire 78 spit quits when warm Triumph 16
regularman Something to warm the heart on a cold winter day. Spridgets 6
T Spitfire Will not restart after warm up, Spitfire mk1 Triumph 15
C TR6 72TR6: Why does it get hard to shift when warm? Triumph 0
C TR6 72TR6: Why does it get hard to shift when warm? Triumph 17
mgb4tim Wedge TR7 FI idle when cold...warm. Triumph 0
P Midget 1500 starts when cold; doesn't when warm Spridgets 9
RickB It's warm & sunny - good 4 Frank! Paint Questions Spridgets 17
George Zeck Difficult / No Start when warm ??? Spridgets 11
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
bluemiata90 Wedge TR8 adjust cold start idle and warm temp idle Triumph 3
regularman I need some warm weather Spridgets 2
DNK Wedge Why is the cockpit of my TR8 so warm. Triumph 16
P Trouble starting a warm Midget 1500 Spridgets 8
AUSMHLY Engine warm up Austin Healey 35
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
S It's warm, so I made a start... finally! Spridgets 4
ncbugeye Overheating now the warm weather is here. Spridgets 10
E 100 studder at high rpm, when warm??? Austin Healey 17
coldplugs Warm-up time Other Cars 6
M Frozen Bonnet Release Despite Warm Weather! MG 8
rulle7 Getting warm in a 1500 Spridgets 6
C Car wont start when warm Jaguar 4
I Warm weather today! Took the XJ out of storage! Jaguar 1
bighly Smoking exhaust after warm-up Austin Healey 13
JPSmit some days your best tool is a credit card Spridgets 2
tj_tr3_tr6 TR4/4A Water leaking into sump 30 days after rebuild Triumph 16
tr6nitjulius General TR Those were the days Triumph 4
