Time for a warm fire and a good book,....
scoutll
because it's snowing already and we are under a blizzard warning. Supposed to get 15 inches of snow and 30-50 mile an hour winds for the next two to three days. Drifts should be roof high by Sunday night. The MG is all bundled up in the garage, the snowblower is full of gas (for when it's over) and luckily, I just bought a copy of "The History of MG".
drooartz
We're in the same shape here, Bryan. It's currently snowing sideways at my place. Good day to hunker down and take it easy.
No Sir Drew. You get out there and start putting the TuneBug back together. Spring will be here before you know it. :wink:
two out of three isn't bad... I'd add a nice single malt whisky to that mix.... :smile:
scoutll
scoutll
Got some 12 year old Glenlivet, some cheap brandy to put in the coffee, and good old american burbon, so that's covered to!
jlaird
Drew, get out in the garage and get the Tunebug project moveing.
drooartz
Got to rest a bit first. Just finished the shoveling/snowblowing/roof clearing project and I'm a bit beat. I will be spending some good time in the garage this weekend, though. No other projects to tackle this weekend.
texas_bugeye
O ya dat be a good storm there fer sure. Just be thankful your gettting snow with the winds. You havn't lived until you have been thru a good old fashion North Dakota SNERT storm. There the worst! Get out the RISK or MONOPLOY game and start playing it's gona be a long couple days..
R TR6 J-Type overdrive will not disengage when warm Triumph 8
drooartz MGB OD question - need to warm up? MG 8
RJS General TR Warm White H4 LED Headlight Bulbs Triumph 1
AUSMHLY E10 Light bulb, 2.2w vs 5w vs warm white LED Austin Healey 4
R Screen for warm air side Austin Healey 26
C TR6 Zenith Strombers won't start when warm. Triumph 2
I TR6 Left wheel gets warm when I drive Triumph 8
A 1985 280i - stalls when warm TVR 6
bighealeysource TR6 TR6 will not start back up after being run for a while and engine warm Triumph 15
T TR4/4A Overdrive fade when engine is running warm Triumph 5
T Dust cap feels surprisingly warm after short drive Triumph 7
Jim_Gruber Running too warm at sustained high speeds Spridgets 5
T TR2/3/3A TR3 Warm Up Issues Triumph 10
M Warm days and air/fuel mixture Triumph 11
RickB Finally warm and sunny, top down and I'm out!! Spridgets 4
BN6_2197 Overdrive not engaging when engine warm Austin Healey 15
T H-E-L-P OD Drops out when warm MG 1
bigjones Needs choke when warm Triumph 8
S MGB My MGB is warm blooded..... MG 7
J 145 - 130 - 155 - 160 warm compression test Triumph 10
B Spitfire 78 spit quits when warm Triumph 16
regularman Something to warm the heart on a cold winter day. Spridgets 6
T Spitfire Will not restart after warm up, Spitfire mk1 Triumph 15
C TR6 72TR6: Why does it get hard to shift when warm? Triumph 0
C TR6 72TR6: Why does it get hard to shift when warm? Triumph 17
mgb4tim Wedge TR7 FI idle when cold...warm. Triumph 0
P Midget 1500 starts when cold; doesn't when warm Spridgets 9
RickB It's warm & sunny - good 4 Frank! Paint Questions Spridgets 17
George Zeck Difficult / No Start when warm ??? Spridgets 11
M Wedge TR7 Won't Start When Engine is Warm... Triumph 4
bluemiata90 Wedge TR8 adjust cold start idle and warm temp idle Triumph 3
regularman I need some warm weather Spridgets 2
DNK Wedge Why is the cockpit of my TR8 so warm. Triumph 16
P Trouble starting a warm Midget 1500 Spridgets 8
AUSMHLY Engine warm up Austin Healey 35
bmurphy7369 XJ6 SII 1975 with Crane Ignition dies when warm Jaguar 10
S It's warm, so I made a start... finally! Spridgets 4
ncbugeye Overheating now the warm weather is here. Spridgets 10
E 100 studder at high rpm, when warm??? Austin Healey 17
coldplugs Warm-up time Other Cars 6
M Frozen Bonnet Release Despite Warm Weather! MG 8
rulle7 Getting warm in a 1500 Spridgets 6
C Car wont start when warm Jaguar 4
Darwin Warm days and sunshine in Montana....... Triumph 2
I Warm weather today! Took the XJ out of storage! Jaguar 1
bighly Smoking exhaust after warm-up Austin Healey 13
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
tr6nitjulius General TR TRF fire Triumph 12
Popeye Elide fire extinguishing balls Restoration & Tools 10
