E10 Light bulb, 2.2w vs 5w vs warm white LED
AUSMHLY
The smith gauges in our Healeys had E10 2.2watt incandescent bulbs. Why was the 2.2 watt bulb used when it really doesn't provide enough lumens? An E10 5 watt will also fit and and lights up the gauge much better. Is it the amount of heat generated by the bulbs an issue, why was the 2.2 was used?
I spent some time on this issue a while back and experimented with E10 bulbs in both incandescent and LED. I found the LED kalvin a bit too white/blue for my vintage taste. So I drilled one then two more holes in the bottom of the speed and tach gauges, and added 2.2w bulbs. I found the stock bulb placement at the top center and the two bulbs at the bottom across from the high beam and generator light bulbs spread the light evenly. In the gas and oil/water gauge I installed a 5w bulb. My concern was how hot that bulb gets. Seems to be ok, for over the years, no problem with those two gauges.
I'm now helping a friend restore his 66 BJ8 and he'd like me to modify his gauges so they are brighter.
So I'm revisiting the LED vs incandescent issue. I like the warm light (vintage look) the incandescent bulbs provide, but I'm concerned about the heat. LED's don't have that issue, so here I go again.
LED have come a long way since I played around with this back in the day. Now they can provide 180 degrees or more dispersion, vs the focused beam when they first came out. I've played with a few "warm white" led's recently and find they are a bit too blue/white vs incandescent. I believe warm white should be in the 2700-3000 Kelvin. I'd prefer to install LED for non heat issue and the bonus of the bulb may out last the car.
Moss and a bunch of other vintage sellers sell E10 LEDs but they don't publish the kelvin. I'm concerned they are over 3000 kalvin, blue/white light.
As much fun as buying and testing bunches of E10 LED's is, any one know of a "warm white"- Vintage lumens ... that disperses 180 degrees or more, has the vintage shade of yellow/white and provides more lumens then the 2.2 filament? Where is that glass slipper LED I'm searching for?
I'm not going to spend as much time on this bulb issue as I did years ago. Three 2.2w incandescent in the speed/tach and one 5w in the gas, water/oil is a hugh improvement over stock set up.
I have LEDs in my BJ8. I have no idea how many Kelvins they have, but they are definitely blue/white. On the rare occasions I find myself driving a 60-year-old death trap--compared to modern cars--at night I am only concerned about being able to read the gauges.
glemon
LBCarco.com has a nice selection of upgraded dash bulbs, though they are not cheap. I used some higher watt incandescents on my Triumph and it is much better at night. I think there was a little meltage on one of the plastic pieces near the bulb but would sacrifice it to be able to see the gauges at night. Interesting how most all old British sports cars have gauge light rheostats when they are absent most any other fancy controls and the stock lighting is awfully dim at it's brightest.
John Turney
I painted the inside of my speedometer case white and left the original bulb alone. Makes a huge difference in the visibility.
bob hughes
I lined mine with self adhesive metal foil - the type that is used on air duct insulation, gosh did that make a difference with the light bouncing every where.
:cheers:
Bob
Rob Glasgow E10 Base LED Dash Bulbs Austin Healey 17
AUSMHLY 2.2 watt E10 gauge bulb Austin Healey 13
J For Sale TR 3 dash warning light lens, used Triumph Classifieds 0
D TR2/3/3A 3D printed tail light Triumph 12
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
B Positive-Ground LED Light Strip Austin Healey 8
bigjones TR2/3/3A Rear tail light not budging Triumph 5
jfarris TR2/3/3A Light show in the turn signal indicator bulb Triumph 2
F TR2/3/3A head light buckets Triumph 3
G Brake Light Switch Failure Austin Healey 24
J TR2/3/3A Red ignition light stays on Triumph 7
Gatheringtree TR2/3/3A LED headlamp and tail light conversion. Triumph 4
C MGB-GT Reproduction light switch MG 13
B Windscreen Pillar/Quarter Light Relationship Austin Healey 2
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
T Tail light extension Spridgets 2
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Another electrical problem: Park light & 5ignal light on Drivers side are brighter than....... Triumph 3
K TR2/3/3A The USA Panel Light Fuse? Triumph 1
rgfrey BN4 Ignition/Turn Indicator Light Austin Healey 7
6 E-Type brake light pressure switch location Jaguar 5
W Healey BN1 Ignition Light Austin Healey 8
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
K TR2/3/3A The two wires that go to the brake light stop switch junction......... Triumph 1
Rob Glasgow LED Dash Light Upgrade Austin Healey 28
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
R side light install Spridgets 2
S TR6 Oil Pressure Light Triumph 2
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
Cappy Ignition Warning Light Austin Healey 6
I TR6 Dash light issues Triumph 19
Hamish Racing TR2/3/3A Remote brake light switch Triumph 5
B Brake light weirdness Dodge Ram Other Cars 5
JPSmit I saw the light! I saw the Light! Restoration & Tools 19
P TR2/3/3A TR3B Panel Light Switch Triumph 20
D TR2/3/3A center panel indicator light color Triumph 10
D TR2/3/3A Brake light switch. Triumph 22
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R Speedo High Beam Warning Light Color Austin Healey 14
steveg Picture needed - front turn light Austin Healey 4
Gliderman8 TR6 Hi-Lo light switch....... Good to have spares Triumph 1
Boink Brake Light Switch... Spridgets 4
RAC68 Third *[3rd] Brake Light Austin Healey 11
V LED light bulbs : One thing leads to another Spridgets 7
V LED light bulbs : One thing leads to another Austin Healey 2
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
