TR2/3/3A Rear tail light not budging
bigjones
Bronze
Trying to put in a replacement bulb but I cannot get the tail light off. I've tried using a metal spackle-spreader but no luck. Are there any suggestions?
bobhustead
If you have the two screws out, it should virtually fall off. Maybe someone put sealant on the edge of the lens? Try inserting a 1/8 inch screwdriver, maybe sharpened, gradually putting it in different spots unti it loosens. You could also try to forcefully wiggle it side to side.
Bob
bigjones
bigjones
Bronze
Bob,
Many thanks for responding.
Yes, I think you are right about the sealant.
It looks like the red reflector is cracked near the screw hole and someone tried to re-use the reflector instead of coughing up and buying a new one.
I'll get back to report on your suggestions.
Cheers!
mrv8q
I recently was looking at my rear lights after about 15 years; the plastic lens was welded to the gasket. I took a small sharp screwdriver but it took quite a while to separate the lens from the housing. I was surprised as much as you were.
N Wanted Early rear tail light lens Triumph Classifieds 0
L TR2/3/3A Rear tail light cutouts Triumph 213
bigbadbluetr6 TR6 Rear tail lights not working. Triumph 17
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
wkilleffer Trouble with tail lights and rear sidemarkers MG 18
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
S TR2/3/3A rear wheel cylinder Triumph 1
T Rear/Differential "Clunk" Austin Healey 2
J 3000 Rear Seats Austin Healey 6
KVH General TR Rear Brake Shoe Orientation Triumph 12
Popeye TR4/4A Rear fender attachment: wing to lamp housing clip? Triumph 7
KVH General Tech Rear Brakes and Solid Axle Triumph 2
P Rear Springs Austin Healey 2
K TR2/3/3A Rear leaf spring brass and Delrin bushings ? Triumph 4
J Rear Main Seal Kit Austin Healey 1
af3683 TR2/3/3A TR-2 / TR-3 Rear Bumper Wrap Around Fender Guards Identification Triumph 0
T Looking for "BillMs rear transmission mount" Spridgets 2
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
Ed Foster T-Series MG-TD leaf rear leaf spring. MG 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
