Hi all,
I am just getting back into full time TR3'ing.
1959 TR3a with recently rebuilt head.
Wondering if it is time to replace the rings.
Just did a warmed up compression test so now I have:
Cold - Warm - Difference
1 - 110 - 145 +35rel
2 - 130 - 130 0
3 - 125 - 155 +30
4 - 125 - 160 +35
#2 cylinder seems the strangest to me with no difference.
Are the +30's considered normal? I am going to do a leak down test as soon as I can get a homegrown tester together.
Another question on a totally different subject. The engine runs great but I have what feels to me like a large dead spot on initial acceleration. It is really bad when dead cold, like to stall out if I am not very careful, but is still there after it is fully warmed up. It is most noticeable when slowing down to make a 90 degree turn either way. I have to make sure that I keep the revs up or it is a while before I can accelerate out of a turn. I don't expect it to respond like a fuel injected car but I know that it has done better than what it is doing now.
Does this have to do with the SU damper oil doing its thing? There was definitely some in them as I could feel the resistance screwing the top in. It might have been a little bit low but not much. Have not given it a test ride since I topped it up. The lighter the oil the quicker the carb response right? I have Marvel Mystery Oil in there now but thinking about putting motor oil in there to see if it makes a difference. I am wondering if the Marvel Mystery oil is too light so that the carb is getting too much air and fuel at the same time. It feels like it has to 'catch its breath' when I get on the pedal too quickly
Could this also be a problem with the timing? Other than this dead spot the engine seems to run really well. Nothing close to a backfire or lugging. I am also wondering if I have the dreaded throttle spindle wear? I can actually bring the rpms down low enough that the car will stop running by standing at the engine and pushing up the linkage without too much force. It appears to have another fraction of an inch that it will sometimes go back to and if I am driving and the car is not warmed up it will stall. I have sprayed carb cleaner on both side of both carbs and not heard any difference in idle so I am kind of puzzled on this. It will be idling fine at about 11 or 1200 rpm and then all of a sudden I will come to a stop and the idle will drop way low...low enough to shut the engine down. I am also wondering if my floats needs adjusting as the shut downs usually happen when I am braking hard and/or pointing down hill. Is there a rule of thumb for where the floats should be?
Thanks to all and happy motoring.
Jim Lee
_________________________
1959 TR3A TS50550L S50715E
2 - 130 - 130 0
3 - 125 - 155 +30
4 - 125 - 160 +35
Jim Lee
