1500 Operating Temperature
GS67
I have a ‘78 Midget 1500 with a rebuilt engine (less than 1000mi) and my temp guage tends to indicate overheat after 40min or so of driving. I’ve flushed the system, replaced the thermostat & sender unit, checked for manifold & gasket leaks and have no indication there’s anything wrong there. When the temp needle gets to just the edge of the red zone on the guage the temp at the thermostat housing (measured by laser thermometer) ranges between about 165-175 degrees and the block between 175-180. I’m tempted to believe the guage is boggled. The car has never boiled over or pushed coolant into the overflow tank.
Does anyone know what the operating range is for temperature? I’m planning on driving the car locally and keeping an eye on things but would like to know how hot is “too hot”.
Thanks,
Gregg
dklawson
There is no single answer regarding the operating temperature. However, when the needle is "centered" on 90 degree sweep Smiths temperature gauge it is typically around 190 oF (roughly 90 oC).
If you painted the t-stat housing black or put a square of electrical tape on it as a target and got a laser measurement of 175-180oF, AND if your car has a 180 oF t-stat installed, trust your measurements and suspect the gauge.
There are several possible fixes:
  1. Buy a new gauge and matching sender.
  2. Send your existing gauge off for calibration. While it is away, you can install an inexpensive gauge from your local parts store.
  3. Give up on Smiths and just use an aftermarket gauge and matching sender (like a decent VDO).
  4. Recalibrate the Smiths gauge yourself on the bench. (Look for online sources (including the link below) that discuss calibration)
  5. It could be a bad or incorrect temperature sending unit. On other British cars the sender changed a few times during production. Do you have a matched sender and gauge?
  6. Buy the "Gauge Wizard" from Spiyda Design in the U.K. and use it to tweak the match between your gauge and your measurements. or...
  7. Just map out with the existing gauge what the temperature really is (what is boiling, what is "normal") and just drive your car.
DIY Calibration: (See the link below AND realize you will need to put your sending unit in a pot of water which you bring to boiling and then slowly allow to cool as you monitor and record the sending unit's resistance curve. Do NOT use the values in the link below as they are for an MGB).
https://www.chicagolandmgclub.com/techtips/mgb/f-gauge_cal.html
Spiyda Design Gauge Wizard: https://www.spiyda.com/fuel-gauge-wizard-mk3.html
The gauge wizard will let you match your gauge and sending unit without altering the gauge... but you will need to create the temperature/resistance curve as I mentioned above in DIY Calibration.
CCURTISS T-Series TF 1500 Operating Temperature? MG 13
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
B 1500 head studs Spridgets 3
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
P Pristine MG TF 1500 Spotted 0
aseriesspares Spitfire What Gearbox are you using. Spitfire / Midget 1500 Triumph 2
aseriesspares What Gearbox are you using. Midget 1500 Spridgets 5
T Putting a Spitfire 1500 into a 1972 Midget Spridgets 6
AN5Sprite T-Series 1955 TF 1500 For Sale This Spring MG 3
JPSmit 1500 slave cylinder question Spridgets 0
bigjones Vacuum advance on a 1500 Spridgets 13
Rut 1500 gas pedal for sale Spridgets 7
dklawson Spitfire Spitfire 1500 Block Decking Following Boring ??? Triumph 4
dklawson Spitfire Spitfire 1500 - Front Pulley Nut Removal? Triumph 2
DanLewis Two midgets available: '79 is free [no engine, trans], running '77 $1500 [NFI] Spridgets 1
DanLewis 1500 cc MG Midget Radiator in a Bugeye??? Spridgets 5
