1500 head studs
Bob Buxbaum
More stupid questions.
The short block is built and ready for the head. I did not notice the differences in the ends of the head studs until I prepared to reinstall them. I have found that two are longer and go in the right rear corner on the block. However, not knowing the the ends are different, I did not look at them upon removal. I see that the end with about 5/8" of threads also has a vertical groove in them. My question is which end goes in the block, and is there a torque value to observe?
Second, after using Google to look into this, I saw a lot of discussion about not reusing them (for various reasons). Before I screw up, should I get new ones?
Lastly, because repair manuals sometimes are wrong (imagine that!!), what is the correct torque, and how should it be applied? (I am used to torque to yield on the few dozen BMW 3s I have built or done head work.)
P.S. I hope everyone had a wonderful Easter Sunday or Passover.
Gerard
It's generally a good practice to replace them.
Rocker pedestal to head is 32 lb/ft
Cylinder head to block 50 lb/ft (1975-76)
dklawson
While it is good practice to replace them, I would not consider it mandatory on a street engine. Look carefully at the threads for any apparent damage and necking. Definitely replace any showing signs of damage.
I thought the longer studs were for use where the lifting eyes are installed. I don't remember any difference in the ends to dictate which went into the block.
Gerard gave you the torque values. My practice is to follow the pattern shown in the manuals in three steps (i.e. All the way around at 20 ft-lb, around again at 35 or 40 ft-lb, and then finish off to the full value. Do not torque the studs into the block. They go in finger tight. Only torque the nuts.
B
Bob Buxbaum
Thank you both. There IS definitely a difference in the threads and thread length. As I said, the short end is threaded about 5/8th" and has a groove. The other end is almost 1" of thread with no groove.
M Moss Brand Head Studs for 1500 Spridgets 4
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
waltesefalcon 1500 head on 1300 Triumph 6
M Better head gasket for a 1500 Spridgets 26
G Spitfire Best Euro 1500 Spit head? Triumph 0
C 1500 Head Job Spridgets 15
tosoutherncars 1500 - head skim - specs? Spridgets 9
SilentUnicorn 1500 Cracked head? Spridgets 3
B Cylinder head removal - 1500 Spridgets 15
zimmy 1500 head needed Spridgets 5
Morris 1500 Head Skim Triumph 1
Morris Skim 1500 head Spridgets 5
G 1500 Midget head bolts Spridgets 7
C LCB header with 1500 single carb inlet manifold Spridgets 1
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
G Spitfire Spitfire 1500 differential whining Triumph 6
M General MG MG 1500 engine 4-91 or 4-110 MG 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
G T-Series 1955 mgtf 1500 lites MG 5
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
G 79 Midget 1500 overheating Spridgets 2
G General MG Leaking Fuel on twin HS4's 1500 MG Midget MG 5
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
M Spitfire 1500 LH Door Triumph Classifieds 0
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
R Spitfire Spitfire 1500 Triumph 3
B MGA Solution! 1600 harness in a 1500 MG 1
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
R Spitfire 1500 gearbox question Triumph 1
R 1500 gearbox question Spridgets 0
A Spitfire Need help with 1980 Spitfire 1500 Triumph 5
A 76 Midget 1500 Oil filter Spridgets 6
M Wanted Twin carb manifold for 1500 Midget or spitfire Spridgets Classified 3
M Rocker feed kit for 1500 from Victoria British Spridgets 0
sparkydave 1500 battery cable colors Spridgets 1
GS67 1500 Operating Temperature Spridgets 2
doc50 Nash Metro w/MGA 1500 discrepancy... Other British Cars 2
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
DrEntropy For Sale MGA intake manifold [1500] MG Classifieds 0
busybrit For Sale 1960 MGA 1500 Restoration Project for sale. MG Classifieds 2
sparkydave 1500 clutch master Spridgets 4
Steve P. 1500 radiator in an earlier 1275 cross flow Midget? Spridgets 2
